TV cables and quick shifts
Old Oct 18, 2000 | 08:12 PM
RedCamaroRS's Avatar
Hey guys,
I have had a problem that I thought I had fixed a week ago. I had readjusted my TV cable and it initially worked great. My engine came to life because I finally felt like I was putting that power to the wheels. The shifting was quick and smooth, not too hard. I tapped on the pedal easily and quickly zoomed along. Now, after messing with the TV cable again, I feel like its back to its old tricks again. I readjusted it again, but the shifts are slow and sluggish. I have to mash down on the gas more to get it to move. Its very frustrating and annoying to drive again. My question is should I try to play around with the cable instead of just doing the normal readjustment by mashing on the gas to WOT after moving the cable? Would this cause problems? Thanks guys
Old Oct 19, 2000 | 04:25 PM
87 Firebird's Avatar
I've had the same problem, Red. I had the thing set PERFECTLY, and within 2 days it's back where it was. I'm gonna see if there's some way I can "lock" the thing into position. I guess a bit o' epoxy should do the trick...
Old Oct 20, 2000 | 01:39 AM
Live305's Avatar
i've adjusted my TV cable by hand and not the recommended way. i haven't had my adjustments "loosen up" the way you guys are having. i did notice that the "push button" on the adjuster housing was really, really stiff. perhaps yours is pushing in to be adjusted when you guys are doing it, but it isn't coming out completely to lock in your new settings. make sure the tab comes all the way out when you're done making your adjustment.
i also noticed that doing the procedure the right way puts the "slush" back in slushbox.
Old Oct 20, 2000 | 09:32 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
I've also had my "minor" adjustments after the "proper" re-adjustment fall out. I imagine the ratchet mechanism on my slider has worn down, after all it looks like it's only plastic, and I assume this is because I always re-adjust the TV once or twice a year.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
DiabloWS6
Southern California Area
Feb 15, 2016 02:08 AM
DiabloWS6
20
Dec 11, 2015 04:12 PM
TheTraut88
Sep 11, 2015 05:16 AM
TheTraut88
Sep 7, 2015 05:22 PM
Buickstaged
Brakes
Sep 4, 2015 07:53 AM
