Torque convertor???
Old Oct 20, 2000 | 12:22 PM
Metallica383's Avatar
Torque convertor???
I am removing my computer controlled carb and distributor. Will the computer still control the torque convertor if I leave it hooked up How does the computer control the tourque convertor is there any way to just leave the computer hooked up with out having to buy a lockup switch?
Old Oct 20, 2000 | 10:17 PM
RP1987GTA's Avatar
Hook the Tqconvert control wires into the acsess port a-b,this will force the computer in to trans test mode,the only draw back to this is the minus value at VVC causing some slight variations in the data codes ...but hell .....nothing else matters
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
[This message has been edited by RP1987GTA (edited October 20, 2000).]
Old Oct 20, 2000 | 10:19 PM
RP1987GTA's Avatar
nahh ya better not ..
no green
Jan 9, 2016 09:22 PM
Galaxie500XL
Oct 1, 2015 01:05 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
