Will a 10bolt rear fit a 9bolt car???
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
As long as it was from another Camaro and had the same rear brakes? My IROC has the 2.77 BW rearend. My mechanic said try and find a 10bolt out of a camaro. I know the gear choices are more plentiful, but is the 10 bolt as strong as the BW axle? My car doesn't have big hp, probably never will.
Best ET 14.413 @95.57 without
pulling valve covers or manifolds.
Also with stock 2.77 rear end!!!
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
All third gen diffs are externally identical. They all have mounting hardware in the same locations. The 10 bolt can be made stronger than stock with a few changes and modifications. I forgot Dan's web page telling how to do it.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
LS6 Big Block buildup now in progress
Best results before the engine blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
Best 60 foot: 1.662
i'd stay with the 9 bolt.....it can take a hell of lot more than that 10
87GTA,350,Auto,MAF screens removed,195 thermostat,cold start injector UNPLUGED,K&N,modified air intake,ADSchip,3:70s,3inch cat back Flowmaster single outlet,TPS.54,Bosch Plat plugs,base timing 6BTDC,22 MPG and runs like a bear,Bilstiens in the rear....,don't let yer meat loaf
Car: 1988 IROC-Z
I kind of figured that the 9bolt is stronger than a 10bolt. But it costs some big bucks to change out a 2.77BW gear to a 3.42. If I could find a complete 9bolt rear end with discs and 3.42s, I would go for it, as long as the cost is reasonable.
My mechanic says a 10bolt could handle some decent power. I don't plan on making 400Hp right away!!!!!!
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
kah992
Aug 19, 2015 02:55 PM
