PLEASE HELP!!!
Old Oct 23, 2000 | 09:31 PM
APCAMARO's Avatar
PLEASE HELP!!!
OKAY A COUPLE OF NIGHT AGO I REALLY TESTED MY REBUILT 89' 700 R4 AND IT DIDNT PASS THE TEST . THE GOVERNOR IS MESSED UP IN IT ( I SUPPOSE) SO WHEN I AM GOING TO BE RACING I ALWAYS SET IT WHERE IT SHIFTS EARLY COMPARED TO NORMAL OPERATION. MY PROBLEM NOW IS THE TV CABLE HAS NO ADJUSTMENT AT ALL. WHEN I GO TO SET IT CORRECTLY IT IS LOOSE AND DOESNT RACHET AT WOT LIKE IT IS SUPPOSED TO. THE CAR WORKS PERFECT IF I SHIFT MANUALLY, BUT IF NOT I JUMPS FROM OD TO D AND BACK AND FORTH, AND WHEN IT DOWN SHIFTS IT KIND OF FREE SPINS BUT NOT ENTIRELY..WHAT DID I DO AND HOW CAN I FIX IT OR REPLACE IT? SORRY IF MY ? IS VAGUE JUST WRITE ME ?'S
THANKS IN ADVANCE
Red 87'Z-28 350 tpi,gutted maf and airbox,
700r4 w/b&m shift kit and cor. servo
Old Oct 23, 2000 | 11:43 PM
IrocManiac's Avatar
GMTech help us out here if you can. It sounds to me like you are having the same problem I was. It ended up I had a bad forward sprag. Try racing it out of overdrive and see if it still slips like that. Mine would free spin if I got on it in overdrive and sometimes it would try to grab but wouldn't completely.
TPI 305,
Gutted airboxes,
gutted MAF,
K&N filters,
Corvette Servo.
14.9@93mph
"Speed kills, wanna live forever, drive a Ford."
Old Oct 24, 2000 | 06:01 AM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
Doesn't sound like anything major, just sounds like the cable may be stretched out. I would try a new one. Its about $20.
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Old Oct 24, 2000 | 12:39 PM
APCAMARO's Avatar
I APPRECIATE THE HELP..THANKS GUYS
