TH350 question..please read
Old Oct 26, 2000 | 11:58 PM
LilJay's Avatar
ok, i have read alot of the posts on swapping a TH350 into a 3rd gen. i have an 89 bird, its a V6 and i am putting a V8 in it. I am going to put a TH350 behind it. I was going to get a drive shaft out of a TH200 car in the junk yard. Then I thought about..are the long shaft TH350's(out of a truck)and a 700R4 the same length? I thought I saw a post about using a 6 or 9in(i cant remember which, but i am assuming its the long shaft version)tranny and using the stock driveshaft. I have both short and long shafts sitting in my garage. Also, I know you have to change the crossmemeber, can I use the crossmember out of a TH200 car? I mean the TH350 is the same length right? so the xmember should work. Last question, anyone know how to "rig" a bracket up for the tourqe arm from the rearend to the tranny, and how big of deal is it if I dont use it? Thanks for all the help. Jay
Old Oct 27, 2000 | 10:44 AM
chicksL69's Avatar
Ok, just did the swap myself, and have posted here many times. Yes, you can use a th200 crossmember, if you use the 9 inch tailshaft 350 then you can use the stock 700 driveshaft, if you use the 6 inch tailshaft(which I did) 350 you have to use a th200 driveshaft-it fits perfect. If I was you, seeing that you have the 9 inch 350, I would use that so you can retain your stock driveshaft. As far as the torque arm bracket, get a Jegs magazine, and look up the brackets that hurst and b&m use, study the pictures, and if you are good at welding, make one, like I did, works perfect if you do it right. You can also find pics of these brackets on the net. Any more questions, e-mail me.
84 Z28 HO
62-67 327 block
new 350 crank
.040 overbore
461 double hump heads
2.02/1.60 valves
edelbrock perf RPM intake
edelbrock 600 cfm carb
th-350 tranny
B&M stage 2 Transpak
aluminum roller rockers
489 lift cam
7 quart oil pan
Keith Black pistons
screw in studs/guideplate
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
sahlomonic
Sep 20, 2015 07:15 PM
eustodp
Sep 20, 2015 05:09 PM
89newfun
Sep 16, 2015 09:28 AM
383cam
Sep 9, 2015 06:01 AM
