new gear set for 92 camaro rs
Old Oct 29, 2000 | 07:39 PM
92blkcamarors305TBI's Avatar
Im wanting to order a new ring gear and pinion set for my 92 camaro stock 10 bolt with 2.73(axle code 8HE) gears to 3.73 gears. im ordering from richmond gear in the summit racing catalog. But there are 3 gm 10 bolt sections to choose the 3.73 gears from (7.5in ring gear, 8.2in ring, and 8.5in ring gear. Which size of ring gear do i have so i can order the right 3.73 gears from the correct section any help would be greatly appreciated.
Old Oct 29, 2000 | 09:48 PM
Mark305TBI's Avatar
Car: '00 Chevrolet Corvette
7.5" 10-bolt is what came in our cars. Make sure you order the one for the 2.73 carrier.
-Mark W.
'88 SC Camaro w/ 305 TBI
Old Oct 29, 2000 | 10:09 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
I have a 92 RS 305 with a 3.73 rear that I changed. I also put an Auburn Pro Series in the rear, boy what a difference!! You will definitely notice an improvement in the performance.
Old Oct 30, 2000 | 12:23 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Actually its 7.625" but they're interchangeable.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Oct 30, 2000 | 12:34 AM
Z28 Boy's Avatar
Car: 1991 Camaro RS
Engine: GMPP 350 HO w/TBI
Transmission: 700R-4
Axle/Gears: 10-bolt w/3.73s
yeah, the '92s had the 7 5/8" with 28 spline axles instead of the earlier (not as good) 7 1/2" and 26 spline axles.
-brian
1991 Camaro RS
Ultra Blue Metallic, T-Tops
GM 350 HO Crate Engine - Vortec Heads, Edelbrock Performer Vortec Intake, Holley 670 CFM Throttle Body, Open Air Cleaner w/14"x3" K&N, Edelbrock TES Headers, Edelbrock Victor Series Water Pump, Accell Superstock Wires, Cap, and Rotor, MSD Blaster Coil, Hypertech Fan Switch & Thermomaster Chip, AC Delco Rapidfires, 3" Cat Back, Flowmaster 40 Series Muffler
700R4 - 2,400 Stall Converter, Vette Servo, Shift Kit, B&M Super Cooler
Brian's 1991 RS
Central NY F-Body Association
z28boy@twcny.rr.com IM name: Z28 Boy
specialized
Jun 18, 2022 09:26 AM
camaro71633
Sep 1, 2015 10:24 AM
hectre13
Aug 26, 2015 08:17 AM
InfinityShade
Aug 22, 2015 08:00 PM
jharrison5
Aug 19, 2015 05:53 PM
