I DOes anyone know what these numbers on my tranny mean?
Old Oct 15, 2000 | 08:24 PM
BLACK Z's Avatar
Car: 86 Z28
Transmission: W/C T-5
Axle/Gears: 9 BOLT 3.45 POSI
10079856 oo/81 13-52-176 16612 13-52-066-925 The tranny is from a 88 iroc and it is a t-5. They came off of the tranny it self and are in order.
86Z28, GM 350, Jet perf Q-jet & chip Dual snorkel air cleaner, Edelbrock performer intake, Edelbrock headers, Edelbrock cat-back, Off road pipe, MSD 6AL, Accel Super Coil, Taylor Spiro-pro wires, Rapid fire plugs, Jet fan switch, World class t-5, Hurst Short Throw Shifter, Ram Flywheel, Center force dual friction clutch,Aluminum drive shaft, BW disc rear 3.45's & a posi, PBR calipers, Earls braided brake lines, Polygrapite bushings all the way around, poly tranny mount & torque arm mount, Hotchkis lower control arms & panhard rod, Rancho limiter straps, KYB struts & shocks, Gm Wonderbar, Edelbrock strut tower brace, SSM sub frame connectors, Jamex lowering springs, Carbon metallic brake pads, Crossed drilled rotors, Mobil 1 Tranny fluid & motor oil, GM syntheic rear end oil, K&N, Grant stering wheel, 1,200 watt system, Jet Black Paint, 91 Z28 rims, 92 wing, Tinted windows.
Old Oct 17, 2000 | 10:43 AM
812MANY's Avatar
I think I saw a post about T-5 numbers around here somewhere.. Do a search... Someone posted every T-5 assembly # from like '84-present.
It can tell you the gear ratios, year and what motor it was originally behind..
Old Oct 19, 2000 | 06:39 AM
BLACK Z's Avatar
Car: 86 Z28
Thanks How do I do A scearch? sorry for the dumb ?
Old Oct 22, 2000 | 10:39 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
10079856 = RPO M39
16612 I'm guessing is the last 5 digits of the car's VIN number.
Not sure on the other codes. They usually mean production dates, plant etc.
Old Oct 30, 2000 | 08:52 PM
BLACK Z's Avatar
Car: 86 Z28
Does anyone know waht a ratio the m39 has? thanks
Old Nov 1, 2000 | 07:11 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
2.95
If you live in Southeastern US, check us out!
South East Thirdgen
"I used to have a handle on life, but then I used it as a plunger and broke it" -The Wave
ASE Master Tech + L1
Savannah, GA
'87 Trans Am-K&N,Cold air induction, SSM SFC, Boxed LCAs, 8mm Accel wires, Flowmaster, 16" GTA rims.
'97 Bonneville SSE
Linson
Oct 24, 2025 02:00 PM
TinnMann2
Canadian Region
16
Jun 18, 2017 05:10 PM
LT1Formula
Oct 8, 2015 08:34 PM
bjpotter
Oct 4, 2015 07:48 PM
Navy8125
Exterior Parts Wanted
Oct 1, 2015 11:24 AM
