TPI + T56= What rear gears.
Old Aug 4, 2008 | 09:21 AM
charlie31603's Avatar
Car: 1987 Chevrolet Camaro Z28 IROCZ
Engine: L98 350, mini ramed and camed
Transmission: T56 6 speed manual
Axle/Gears: 10 bolt 3:73 limited slip
Alright. I have an 87 IROC 350 TPI with the common bolt ons. And I want to do a rear gear swap. I have heard that the stockish TPI motors don't like anything above a 3:42, do to you not staying in the power band as long. And the T56's don't like anything lower then a 3:73, do to it having such a low first gear. So this is my delima. The car is not a daily driver. So I can somewhat careless about the gas mileage. It dose do highway allot though. The car is mainly a street car. It will set both the dragstrip and autocross track a few times. So what gears do I need to go with. Thanks in advance for all the help! Adam :-)
Old Aug 4, 2008 | 09:33 AM
avro206's Avatar
Car: 89 Formula
Transmission: TH 700R4
Re: TPI + T56= What rear gears.
I don't know why you think anything below 3.73s is not good for a T56---all the 4th gens had 3.42s.
Don't just look at the rear end ratio---its combo of the first gear AND the rear end.
Since the T56 has a lower numericaly first gear VS a 700R4---I don't see why 3.73s would be a problem.
Old Aug 4, 2008 | 10:41 AM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
3.73's will be perfict for you, I find 4.10 was little much for my TPI car plus with the 3.73's and t-56 the highway drive fit's into a more comfortable RPM.
Old Aug 4, 2008 | 12:39 PM
kennn's Avatar
Car: 1990 Nissan 240SX
Engine: GMPP Gen0 350 small block
Transmission: WC T5
Axle/Gears: Nissan R200 3.133, Tomei 2-way
Also don't forget engine torque, redline/rev limiter, and acceptable cruising RPM as well.
hectre13
Aug 26, 2015 08:17 AM
jharrison5
Aug 19, 2015 05:53 PM
Sanjay
Aug 12, 2015 03:41 PM
novaderrik
Aug 10, 2015 12:44 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
