REAR ???
Old Nov 5, 2000 | 01:15 PM
APCAMARO's Avatar
REAR ???
I HAVE A 87 CAMARO THAT CAME WITH A 305 TPI, AND I WAS TOLD IT CAME WITH BORG WARNER 9 BOLT REAR END. IS THAT A POSI? JUST RECENTLY I NOTICED THAT JUST ONE TIRE STARTED SPINNING INSTEAD OF BOTH, IS IT JUST WONR OUT OR WHAT? IF IT IS WHAT DOES IT INVOLVE TO FIX IT? IS IT SOMETHING YOU HAVE TO HAVE DONE OR CAN YOU DO IT AT HOME?
Red 87'Z-28 350 tpi,MSD ignition 6al,gutted maf and airbox,
700r4 w/b&m shift kit and cor. servo
Old Nov 5, 2000 | 01:21 PM
WS - 666's Avatar
TURN YOUR CAPS LOCK OFF PLEASE
Thanks.
Block off the front wheels and raise the rear of the car up. Spin one wheel. If the other one doesn't spin, then it's an open rearend. You can also check the axle code vs. the codes on this site.
hectre13
Dec 11, 2023 08:14 AM
1992 Trans Am
May 10, 2023 07:19 PM
customblackbird
Aug 15, 2021 10:16 PM
Vintageracer
Jan 10, 2020 05:33 PM
Bstrang6
Brakes
Aug 24, 2015 06:45 AM
