should my gear have broke running 13.7 et's
Old Nov 6, 2000 | 11:22 AM
bad camaro RS's Avatar
buddy of mine chucked his ring gear saturday in his 87iroc running 13.7 is this normal it was a 410 gm gear he was running et slicks dropping it from 2000-2400 off line jus curios cause im running a richmond 373 and im running 13.3 to 13.5 with 1.8 60ft and his 60ft was 1.9 to 2.0 was his jus not set up right or something thanks Ron
1992 camaro RS
373 10 bolt rearend
ssm sfc's
87 350 TPI
bored 30 over
compucam 2032 with 1.6
482-495 LIFT 214-220 duration full roller rockers
msd6AL
1 5/8 headman headers
2 `1/2 flowmaster exuast
k&n filters gutter air box gutted maf
3 pc under drive pulleys
no emissions no egr etc
custom ED Wright chip
eddelbroc intake base and runners ported plenum
midly ported and polished stock heads
Taylor 8mm wires
B&M mega shifter
gutted maf/airbox
hotchkis lower control arms
3" exhuast cutout
homemade cold air intake
2000 tci stall
700R4 with B&M shift kit
new best ET 13.5 @104.66
Old Nov 6, 2000 | 01:10 PM
TRAXION's Avatar
Car: 2005 Subaru STI
Engine: 153ci of Turbo Power!
Transmission: 6-Speed
The reason your buddy broke his ring gear is due in part to running a manual tranny. Manual trannys shock the driveline very aggressively. In contrast to this is the automatic transmission which does not shock the driveline as much. I pull consistent 1.7x 60ft times in my car which has the 10-bolt (albeit modified somewhat) and don't have any problems. But, I have an automatic.
Manuals are really really hard on rearends and driveshafts
Autos are softer on rearends and driveshafts
Tim
TRAXION's 1990 IROC-Z
Best Time = 12.244 @ 112.51mph (1.778 60' / 7.819@88.32mph in the 1/8)
All Natural. No Force. No Drugs. Stock Bottom End. Stock Body Panels.
Gunning for NA 11's after installing Hooker LT Headers and reducing weight.
-=ICON Motorsports=-
Moderator: PROM board at thirdgen.org
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
