5th gear is gone t5 no!
Old Aug 5, 2008 | 08:09 PM
RandyZ's Avatar
Car: 1983 & 1993 camaro z28
Engine: 5.0 carbed/ LT1 injected
Transmission: T5/auto
Axle/Gears: 373/posi
i was driving in 5th on the highway and poof it was gone no grinding no nothing no sights anyone easle every had this happen. Is it somthing i can fix
Old Aug 6, 2008 | 05:20 AM
Pat Hall's Avatar
Re: 5th gear is gone t5 no!
You'll have to remove the tailshaft housing to see. 5th gear is located in the tailshaft area. There's a snap ring that holds 5th gear in place, and it's supposedly prone to coming off. If you're lucky, that's your problem, and should be a fairly easy fix. You'll have to drop the trans to remove the tailshaft housing though.
Old Aug 6, 2008 | 05:25 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
The snap ring for 5th gear coming off is a pretty common thing. Yes you will have to remove the transmission from the car, and remove the tailshaft to replace it.
Old Aug 9, 2008 | 05:42 PM
RandyZ's Avatar
has anyone ever replaced the snap ring any pics of it ??????
db057
Apr 28, 2019 07:45 AM
88rscamar0
Sep 23, 2015 09:08 PM
Stroopwafel
Sep 11, 2015 06:38 AM
georgiaslim45
Sep 9, 2015 08:11 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
