Converter swap ????
Old Nov 5, 2000 | 08:01 PM
Z28IROC350's Avatar
Converter swap ????
I'm gonna have to install a new converter in my 87 Iroc next weekend. I was wondering if you have to completely drop the tranny, or if you can unbolt it and slide it back far enough to get inside it. Either way, whats the best procedure for doing this swap ? Thanx in advance :-)
Old Nov 6, 2000 | 10:35 PM
ronterry's Avatar
Car: '94 Corvette
To do this with the least fustration, you really need to drop the tranmission.
You don't realy need to pull from under the car, but you need to pull it down & away from the engine to give you plenty of room.
The Converter is very heavy when your trying to lift it on your back, and you need to make sure it's fully seated. Your old one is going wiegh a bunch, cause that sucker is full of oil.
Let me tell you, them things are a turd to put on when the trannie is sitting on the garage floor, especially when the converter is new cause the tollerances are super close between the converter and your input shaft.
Good Luck,
Ron C. Terry
'82 Trans Am
'81 Camaro Z-28
'94 Vette LT1 Coupe
1992 Trans Am
May 10, 2023 07:19 PM
1984HO
Mar 19, 2021 11:59 AM
smokingss
LSX and LTX Parts
Mar 3, 2016 07:40 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
gwade12
Aug 8, 2015 08:17 AM
