rear end
Old Nov 9, 2000 | 04:46 PM
blck80z28's Avatar
rear end
I have an 87 ta with a 10 bolt limited slip rear with drums.Can i just swap the stock unit to a posi or do i have to buy a hole posi rear. If i can swap the the stock to a posi with out getting rid of the hole rear how would i go about doing that. Also is it worth it or should i just get a hole posi rear from drum to drum,if i just swap the pumkin will it work and will it last.
thanks for any help
matt
Old Nov 9, 2000 | 06:09 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
"Posi" and "limited slip" are different names for the same thing. As long as you aren't slipping one wheel, indicating your limited slip posi is worn out, you don't need to replace anything.
82 Berlinetta, orig V-6 car. Rescued w/86 LG4/TH700R with all harnesses, sensors, ECM, etc. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, exhaust, paint, etc.).
57 Bel Air, my 1st car. Currently 396 .030 over, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
[This message has been edited by five7kid (edited November 09, 2000).]
Old Nov 9, 2000 | 06:51 PM
blck80z28's Avatar
I only have one tire spinning when i drag and i dont get good or any traction and i have seen manuals with both tires spinning.
I just wanted to know is that posi and if it is is it worth it to use my ten bolt to swap
Old Nov 9, 2000 | 11:36 PM
five7kid's Avatar
Okay, let's try this again. You said:
You then ask if you can change the stock unit (limited slip) "to a posi". Again, they are different names for the same thing.
If you are sure that your differential is "limited slip", but that only one tire turns on a hard take-off, then your "limited slip" posi unit is worn out.
You can do any of the options you mentioned, except anything that involves disassembly of the differential itself is a shop job. If you replace the entire rear end, that is a job you can do yourself.
You can have the posi rebuilt, get a used carrier, or buy an aftermarket part such as an Auburn. The used carrier would probably be less expensive, but the least likely to serve well.
Getting a whole rear end that you put in yourself would probably be the least expensive (especially if you stay with drums), assuming you can find one with gears you like, but would have the same likelihood of not lasting long like a used carrier.
It would be worth it to get your current unit rebuilt, or getting a new carrier.
Old Nov 10, 2000 | 01:10 PM
blck80z28's Avatar
Ok that was much more helpful
thanks
matt
hectre13
Dec 11, 2023 08:14 AM
Warlocksirix
Sep 3, 2015 12:26 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
Jlanz55
Aug 17, 2015 07:15 AM
