700 r4 2nd to 3rd clunk?
Old Aug 9, 2008 | 04:47 PM
MADMAXGTA's Avatar
Car: 89 TTA
700r4 is clunking from 2nd to 3rd after I recently installed a spohn adjustable torque arm.
1st to 2nd is smooth,3rd to overdrive is smooth,and it only seems to do this under light accelration.
the shift is firm and quik but it gives a thunk similair to a brokin trans mount. fluid level is good
stage 2 700r4 from bowtie overdrives with apporximatly 2500 miles
your input is greatly appreciated,thx
Old Aug 9, 2008 | 07:44 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 700 r4 2nd to 3rd clunk?
Clunk maybe sounds like it is from the rear? Common issue. The 2-3 shift timing is off, and is binding by being in two gears at the same time. The transmission stops applying forward power to the driveshaft which opens up the clearances in the axles splines, ring & pinion, u-joints, etc. Once the transmission un-binds the slack is taken up with a clunk.
RBob.
Old Aug 9, 2008 | 09:40 PM
MADMAXGTA's Avatar
Car: 89 TTA
how do i fix 2-3rd gear timing?
Last edited by MADMAXGTA; Aug 10, 2008 at 12:25 AM. Reason: this question makes more sence
Old Aug 10, 2008 | 01:35 AM
MADMAXGTA's Avatar
Car: 89 TTA
readjusted tv cable according to the tv cable thread,nothing changed.
But I do notice every bump in the road with this new spohn adj torque arm.
the smallest bump feels louder then the 2nd to 3rd shift im talking about.
Is it possible that the tranny just has a firm,healthy 2nd to 3rd shift,and I
just didnt notice it with the stock torque arm?
but Id hate to think that and burn my tranny up.
Old Aug 10, 2008 | 02:43 AM
CRAMOS78's Avatar
Car: 92 camaro
Engine: stroker
Transmission: Megaraptor
r u talkin about the crossmember torque arm deal?........
it might just be torque arm being too loose and hitting the tunnel...
Old Aug 10, 2008 | 02:45 AM
MADMAXGTA's Avatar
Car: 89 TTA
yea.. i think it sucks so far.
really? wouldnt it do it from 1st to 2nd to?
Old Aug 10, 2008 | 11:44 AM
Burnout91's Avatar
Car: '91 Z28 L98 G92
Engine: Modded L98
Transmission: Modded 700R4
Axle/Gears: Modded 10-Bolt
There is a modification you can do to the 2-4 servo in the trans that helps the 2-3 clunk a lot. The instructions for the mod are included in the ProBuilt Automatics modified TransGo shift kit. Call Dana at ProBuilt.....or....... go to
( www.700r4l60e.com ).
Bill
1986camarojoe
May 23, 2004 09:59 AM
2L8ULOZ
Nov 26, 2002 11:20 AM
foney_email
Aug 3, 2002 06:59 AM
fizzak
Aug 6, 2001 04:33 PM
whiteroc
Jun 25, 2001 05:43 AM
