One wheel spin w/posi ??????
Old Aug 10, 2008 | 05:23 PM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
Transmission: 700R4 w/corvette stall and servo
Axle/Gears: 1998 Transam 2.73 posi.
hey guys, i finally got my 88 formula 5.7 to the 1/4 track in Baytown last friday. After I got those freakin' headers on !!!!My first run she ran 16.43 @ 91.95 with a 60 ft. of 2.83.That was spinning the right tire about an 1/8 of a mile. Dropped my tire pressure down to 20#s,found out that was the wrong thing to do with radails. I made bout 4 runs trying diff. tire pressures. The right rear tire was the only one I could get to spin.(with water or without) Either the track finally came around, or I might have got a pressure right(30#s the both), my last two runs I hooked up a little, and ran a best of 14.44 @ 94.92.That was babying her off the line,with cutout opened, 60 ft. time was 2.02. She weights 3540#s. But even then it was still one wheel spin during the burnout.Right side covered with rubber, left side is clean when I got home.
Anyway my question is.....can a posi wear out? On the street I don't have near the trouble hooking up. But I know the track is diff. than dry clean concrete.I am also running the cheapo Discount Tires 215/60/16's that came on the car. But I sure thought it would hook better than it did. I will be getting better tires maybe 245/50/16, that came on the car new.
Question #2 I am running factory rims with the WS6 pkg. How wide are my rims? I think they are 8" wide.
#3 What is a good street tire than also performs will at the track?
#4 What is the widest tire than will fit on factory rims?
Well that's about 3 more questions than I had planned on asking...
Any help would be really welcomed, especially on the about a posi wearing out.
thanks again.
Old Aug 10, 2008 | 05:49 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: One wheel spin w/posi ??????
Originally Posted by 350fomula
]Anyway my question is.....can a posi wear out?
Yes.
JamesC
Old Aug 10, 2008 | 06:23 PM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
Old Aug 10, 2008 | 11:53 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
you should have 8 inch rims. The biggest tire you would want to put on would be a 255 50 16. I have heard some people go a little bigger, but a 255 would definately work well for you.
Old Aug 11, 2008 | 07:42 PM
89Nighthawk's Avatar
Car: 89 GTA Nighthawk
Engine: 389 CID Vortec TPI
Transmission: TCI 700R4 w/Vigilante
It sounds like your posi is wore out either clutch pack or cones depending on the rearend.
BF Goodrich makes a 265 that fits and I had them on my 84 TA, but I wouldn't recommend them. The best thing to do is look at tread width as my Goodyear 245's have a wider tread than the 265's did and hook better as well.
Goodluck, maybe my son and I will see you at Baytown.
Old Aug 11, 2008 | 08:51 PM
350fomula's Avatar
Car: 1988 Formula
Engine: 350 L98
Thanks......Pyle Bros. said I had an Australian 9 bolt(I think that's what he called it), when I went there acouple of months age looking for 3.73 gears. They said they could'nt get gears for that rear end anymore?!?
Well maybe they still get parts. I plan on taking it in next week.
Old Aug 11, 2008 | 09:15 PM
Saber's Avatar
Car: 91 camaro RS, 87 T/A
Engine: 350 TBI, 305 TPI
Axle/Gears: 4th Gen 3.42/BW 3.45
Same exact thing happened to me, took it to the track only to find out my posi was gone. i had a 9 bolt also, i switched to a 4th gen rear cause i couldnt find any parts for it at a reasonable price, the 9 bolt is a pretty hard thing to find parts for, although in my search i found out a guy named gevo from gevo's rears and gears has access to some parts and www.difsolutions.com sells gears for the 9 bolt although he is rather pricey. And you could always shim it, search for that, there is a nice thread on it. Shimming it could last for a week or for ever, most people have decent results though. In the end though it cost me 200$ to get it shimmed, or 250$ for a new 4th gen rear.
obeymybird
Exterior Parts for Sale
Nov 3, 2015 08:10 AM
drptop70ss
Oct 4, 2015 09:44 PM
Fionnla
Wheels and Tires
Sep 11, 2015 11:07 PM
punkmaster98
Sep 8, 2015 09:45 PM
turbobuick88
Wheels and Tires
Sep 8, 2015 08:27 PM
