So what's the deal???
Old Nov 12, 2000 | 04:16 AM
T/A1988's Avatar
I've heard some people say the a T-5 can't take the power of a 350, some people say it can. I don't want a T-56, WAY too expensive. I was hoping to pick up a used T-5 cheap. The problem is my 350. Is there any way to rebuild it to handle the power? Thanks.
Old Nov 12, 2000 | 12:44 PM
merf23's Avatar
The problem with the t-5's is that the cases stretch between the mainshaft and countershaft causing the gears to mis-mesh. The later WC T-5 use tapered roller bearings on the counter shaft as well as some other updates, so they can handle more power. The T-5 will hold up if you dont abuse it (ie dont dump the clutch @4K, use the clutch, etc). If you get one, I suggest you check all the clearances before installation.
Old Nov 12, 2000 | 02:57 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
depends on the power of the 350. They can hold L98s, but a super ram with nitrous will grenade it
Old Nov 15, 2000 | 09:49 AM
T/A1988's Avatar
Is there some sort of race rebuild kit I could buy to make it stronger?
AmpleUnicorn88
South West Region
Dec 11, 2015 11:53 PM
LT1Formula
Oct 8, 2015 08:34 PM
TexasFormula
Sep 30, 2015 06:36 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
Dragonsys
Sep 25, 2015 03:51 PM
