torque converter to fly wheal gap
Old Aug 13, 2008 | 10:05 AM
z28z34man's Avatar
Car: 1984 z28 camaro / 2019 accord sport
I have searched and pro built said .08" - .12" was ideal before you tighten the torque converter. Mine is .13" will I be ok or should I get 3 .03" thickness washers use them as spacers then tighten up the torque converter
Old Aug 13, 2008 | 02:26 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: torque converter to fly wheal gap
You'll be fine.
Old Aug 13, 2008 | 02:46 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
at least a car space as they shouldn't be on the same car.
Old Aug 14, 2008 | 05:18 PM
z28z34man's Avatar
thanks the car is finally coming back together at a decent rate
Old Aug 15, 2008 | 01:06 AM
Pro Built Automatics's Avatar
I have recommended .080" - .125" clearance. If you have .130", that is .005" over the recommendation, don't worry about it. If you already have the .030" washers, go ahead and add them.
Old Aug 16, 2008 | 07:27 PM
85ZzZ4's Avatar
Car: 2005 Chevy Colorado/ 1985 Z28
Engine: fast burn zz4
Transmission: th350
Axle/Gears: 10 bolt (has to go) 3:23 gears
my gap is bigger than this by quite a bit... what should i do?
Old Aug 16, 2008 | 09:18 PM
What gap do you have?
88rscamar0
Sep 23, 2015 09:08 PM
Ragtop Man
Sep 12, 2015 12:23 AM
Nick McCardle
Sep 10, 2015 08:36 PM
89fast5oh
Sep 8, 2015 09:55 AM
