Very nasty sounding grind going into reverse
Old Aug 14, 2008 | 08:37 PM
BladeX10's Avatar
Car: 1991 RS v8
I tried to get my car going for the first time in a week or so.. I already know my 1st gear is almost impossible to get into but when i try and get it into reverse.. It makes a very very nasty grinding noise.. Like you can hear it 20-30 feet away..Sounds like someone put a handful of metal chunks in a blender.. And it wont even go into reverse.. unless i have to put a crapload of force into it but im scared to do so.
What is the problem?
Old Aug 14, 2008 | 11:12 PM
Tony89GTA's Avatar
Car: 89 GTA
Engine: 5.7L Supercharged
Axle/Gears: Moser 9" 3.70
Re: Very nasty sounding grind going into reverse
Sounds like your clutch is not releasing.
Old Aug 15, 2008 | 12:19 AM
BladeX10's Avatar
Car: 1991 RS v8
Yeah.. The guy i bought it from said the clutch was pretty much done.. I did wanted to figure out what that grinding noise was because it didnt sound to nice.. thought my transmission was taking a dump or something.
Old Aug 15, 2008 | 06:43 AM
Tony89GTA's Avatar
Car: 89 GTA
The t-5 has no reverse syncro's so your really smashing up your teeth on the gear cause the shaft is still moving. Once you get the clutch replaced or figure out what's wrong with it, could be master/slave problem to, try putting the tranny into a forward gear first before you put it into reverse, helps with the shift.
Old Aug 17, 2008 | 03:46 AM
samiam91RS's Avatar
Car: 91 RS
Axle/Gears: 3.45
mine did that too, was pretty bad noise. so i used to put it in 1st for a sec then reverse and it was good. now i even slap it in 5th then slap it straight down into reverse and it doesnt make a sound. hopes this helps.
db057
Jan 10, 2020 08:55 PM
Elephantismo
Feb 13, 2019 12:51 AM
Loudnproud86
Jul 14, 2016 12:59 AM
84redta
Sep 19, 2015 09:58 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
