tcc jumper question
Old Aug 13, 2008 | 04:12 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
tcc jumper question
so i saw the tech article on jumpering the computer terminals to force lockup the tcc in 2nd-OD and thought i would try it on another car of mine.
the car has a th-350 transmission, and when i started driving i noticed that 2nd did not force a lockup, but 3rd did.
i was just curious if i should try a different jumper configuration or if this was how the th350 is no matter what.
(yeah, i know, 350 trannys are LAME, but hey, dont hate. actually, i'd like to put an underdrive (like 1.75-2:1) unit on back and put a 2.53 rear end in. i already have a 2.93 rear and turn 2100 or so on the highway at 65. a 2.53 would be just about perfect)
Old Aug 17, 2008 | 04:12 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: tcc jumper question
The 200 & 700 trannies have a hydraulic circuit that keeps the TCC from locking up in 1st even if the solenoid commands it to do so or is sticking.
I don't know much about the 350 but I guess it could have a couple of pressure switches in series with the solenoid to keep it from locking up in low gears that way.
If that's the way it works then I don't think there's anything you can do about it apart from doing some rewiring internally in the tranny.
There's certainly nothing else to try using the diagnostic connector.
specialized
Jun 18, 2022 09:26 AM
jklein337
Sep 19, 2018 06:23 PM
Eric2ndGen
Nov 5, 2015 01:51 PM
5spdcamaro
Aug 28, 2015 02:12 AM
redmaroz
Aug 16, 2015 11:40 PM
