Axle Splines on 86 Camaro
HOw can i figure out if i have 26 or 28 spline axles without taking the rear-end cover off? IT is an 86 camaro rear-end out of a 2.8v-6 with 3.42 gears. Also i'm thinking about buying a auburn OEM posi-takeoff off the internet. it is off a 4th gen camaro. would it work inside my rear-end? thanks for the help
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
If you can't find some 28 spline axles from a 90-92 then you can get a set of aftermarket ones from drivetraindirect part number KAC7-A7
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car and knocking on the SuperPro ET class
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857
Best corrected ET: 11.163
Best MPH on a time slip: 117.87
Best corrected MPH: 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
How much are they from drivetraindirect?
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
-Justin-
Car: 87 IROC L98
$125 each.
They are basically race axles. Non tapered shafts. The flange is drilled for 1/2" screw in studs. I'm sure it also has holes for stock press in type studs. They'll work with disk or drum brakes.
You'll need a 28 spline carrier to use them. I first just tryed some 28 spline side gears but the axles won't fit in the 26 spline carrier itself. You can drill the hole out to 1 1/4" or just get the whole 28 spline carrier. Either find one from a 90 and up f-body or S-10/S-15 or get the SLP Torsen carrier.
[This message has been edited by Stephen 87 IROC (edited November 17, 2000).]
Not bad, considering Dal wanted $200 each stock GM.
-Justin-
-Justin-
hectre13
Dec 11, 2023 08:14 AM
red90IROCls1
Aug 25, 2015 06:56 AM
