Transmission Reinstall Questions...
Car: '89 Chevrolet Camaro IROC-Z
Transmission: TH-700R4
Axle/Gears: B&W 2.77 Posi
I'm going to be installing my rebuilt automatic transmission back into my '89 IROC this weekend and just had a couple of questions before I embark...
1. I am replacing the original torque converter with a rebuilt one. Does the orientation of the torque converter relative to the flexplate matter?
2. Are there any special break-in procedures that I need to be aware of after I get everything back in? Currently the transmission is fresh from the rebuilder on my garage floor and I would imagine it's bone-dry; obviously it needs fluid. I'll fill up the torque converter as best as I can before putting it in. After fluid is in, is it just a matter of starting it up and driving?
Thanks in advance.
Thanks in advance.
Car: 1986 Z28 Camaro, 2002 Audi A4 (DD)
Engine: 350 .30 over w/bang for buck combo
Axle/Gears: stock for now
Re: Transmission Reinstall Questions...
fill 1 quart of tranny fluid into the torque converter.. make sure the tranny has fluid in it .. then just install the torque converter on the tranny making sure it locks in to the pump. as far as bolting it up to the flex plate make sure the tranny is in neutral so that you can easily turn the torque converter to match up with the flexplate bolt holes
Axle/Gears: '01 3.42 10 bolt
doesn't matter what gear it is in, it will not effect the amount of effort to turn the torque converter. nothing in the tranny will be applied.
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
