t5 launches
Old 08-14-2008, 10:39 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
t5 launches
How do you t5'ers prepare and do a good clean launch with stock clutch and flywheel(although my flywheel was $$$ because I had to fit to a 10.5inch clutch with a 2 piece rms...id assume thats concidered stock)
Old 08-14-2008, 10:58 PM
82whiteZ28's Avatar
Car: 1982 Camaro z28
Engine: 5.3
Transmission: TKX
Axle/Gears: 10 BOLT
Re: t5 launches
i side step mine at 5k
Old 08-17-2008, 04:50 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: t5 launches
can you go more into detail please?
Old 08-17-2008, 09:38 PM
69charger383's Avatar
Car: 2005 Lincoln LS, 83' Z28
Engine: 242 DOHC and an empty engine bay.
Transmission: 5R55S, T5 soon to be auto
Axle/Gears: 3.58s and soon to be 4.10s
Re: t5 launches
uh basically he means bringing it up to 5K with the clutch in and then moving your foot off the side of the pedal, IE sidestep.. if you have grippy tires dont ever do this with a T5.. I usually bring it up to around 3500-4000 and just feather it out, yea not so good on the clutch but id rather pay 100 bux for a clutch than 500-1500 for another T5..
Old 08-17-2008, 11:35 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: t5 launches
well what if your tires aren't slicks?
Old 08-18-2008, 10:37 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: t5 launches
I have a stock flywheel and a heavy duty napa truck clutch. Since my car makes a ton of low end torque and not much above 4500 I bring the revs up to about 2200 and slip the clutch while laying into the gas just enough to keep the motor from bogging. I've been cutting roughly 2.0 or 1.9 60 foots with street tires, turning a mid to low 13 over all
Old 08-26-2008, 11:14 PM
autotec101's Avatar
Car: 86 bird
Transmission: 5 spd
Re: t5 launches
A good and safe launch would be rev up to 3k ease the clutch out 1/2 way (when the car just starts to move ) pop the clutch the rest of the way, and put your gas pedal down.when theres pinks on the line I still use this launch, the next doesnt do crap for any parts, I hold the gas to the floor and still clutch but pop it up , all the way to 4th
darwinprice
17
10-11-2015 11:51 PM
tuningnewb
09-23-2015 07:06 PM
Chevy3shitty
09-01-2015 02:10 AM
beast94
08-20-2015 06:44 AM
Quick Reply: t5 launches
