Hey guys... On my way back from work today I noticed that the tranny shifted a lot harder. It got progressively worse as I was approaching home where it would only shift around 5500 from 1st to 2nd and around 4500 from 2nd to 3rd. At WOT it shifts just fine. Looked at the fluid... a little low. Put a half of quart in and it came back up to the hot level on the dipstick. However it didnt cure the problem at all. From what I read so far, it sounds like I have either a bad or sticking governor or a sticking TV cable. What do you guys think it is ? This tranny only has 3000 miles on it. It was a warranty rebuild. Thanx
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
[This message has been edited by Blade (edited November 23, 2000).]
92 Z28 L98 350
Sounds like the TV Valve is stuck in the valvebody, wich isn't too uncommon for the 700R-4. You can try re-adjusting it and see if it doesn't free it up.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey,
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
22# injectors,
JET AFPR,
Ported Plenum,
TB Coolant Bypass,
SSM SFC,
Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
