Aluminum Driveshaft--Need Help!!
Old Nov 21, 2000 | 06:23 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
I'm thinking about purchasing one, but I don't know if it will work with my transmission. Are the driveshafts different for automatic and manual transmissions? If not, I'm going for it. Please let me know.
Old Nov 21, 2000 | 03:20 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Driveshafts all the same for all V8 thirdgens with overdrive transmissions. I think the V6's are the same too. You can even use a driveshaft from an LT1 4th gen.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 22, 2000 | 07:12 AM
Mark W. Winning's Avatar
Some of the 4th gens had aluminum driveshafts. I got mine from a salvage yard. Paid about $100 for it. Fit my 3rd gen perfectly.
1992 Pontiac Firebird 350/Six Speed
1987 Toyota Pickup 383/500+ HP
Old Nov 22, 2000 | 11:10 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
I forgot to mention (DUH!) the car the driveshaft is coming from is an automatic, but my car has the world class T-5, will it work?
Old Nov 23, 2000 | 02:40 AM
Justins86bird's Avatar
Car: 86 LG4 & 92 TBI Firebird
Engine: The Mighty 305!
Auto and manual have the same d/s.
-Justin-
T-Top '86 5.0L LG4 700R4 WS6 Now Bilstein equipped!
T-Top '92 5.0L TBI 700R4
My '86 Firebird Homepage
The F-body Model Kit Pictoral Archive (updated 9/18/00)
There can be only one!!
Old Nov 24, 2000 | 06:39 PM
IrocStan's Avatar
Visually, the automatic and stick driveshafts look the same. But I know for a fact that the forth gen 6 speed aluminum d/s have a cardboard liner for sound deadening while the automatic cars have no inner liners.
Also, the 4th gen aluminium driveshafts have a balancer on the front slip yoke. I allways had a vibration problem when cruising at 70 or so. I thought that it was a tire, but as soon as I put the 4th gen aluminum driveshaft in it was gone. I am considering taking it off and putting a regular slip yoke in for weight reduction, but it would be about a half inch shorter. I don't know if it would cause any problems.
87 IROC 350, 3:42 Torsen
13.94@103mph, 2.25 60'
Stock cam, chip and trans
In the works: ported SLP runners, ported base, Xtreme Cam, homemade suspension pieces, and 27x10 Hoosiers.
Hoping for 12.999
Linson
Oct 24, 2025 02:00 PM
Royal_Z
Sep 30, 2015 08:45 PM
