cant figure out whats with my stall
Old Aug 18, 2008 | 08:42 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
Hey guys i got a 3500 stall on a built 700r4
I have a 4th gen rear with 3.42 gears
I was at the track tryin to launch and i couldnt brake stall it past 2100 rpms without it moving. i feel like trhe converter is tooo tight but im not sure. What kind of tests can i run to see if this is true
Old Aug 19, 2008 | 05:41 PM
DPSJosh's Avatar
Car: 1987 Trans Am
Engine: Forged 383 with Brodix Heads
Transmission: Pro-Built TH400
Axle/Gears: 9-Bolt 4.11s with Posi
Re: cant figure out whats with my stall
It really depends what kind of power you're making and how good your brakes can hold you. You probably won't ever see 3500rpms without decent power and a trans brake. 2100rpm sounds a little low, but I'm sure someone else will chime in. What brand is the torque converter?
Old Aug 19, 2008 | 09:24 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
I can't hold past 1500 rpm. Its typical for the brakes not to hold at that high of rpm.
Old Aug 20, 2008 | 02:02 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
ya im guessing its fine.
Old Aug 20, 2008 | 03:25 PM
Fast 383's Avatar
Car: 1986 Camaro SC
Engine: None
Transmission: None
Axle/Gears: Moser 9" W/ spool 3.50 gears
A car will rarely ever see a true stall without a trans brake. Your car has to many factors in the way for the converter to make it to the speed it needs to go to lock up. ex...tire spin, front brakes not holding etc...
How does the car feel with normal driving. Does it seem loose and sloppy for about 1/4 to 1/2 the pedal? What type of converter do you have and is it a 10inch or 12 inch?
Does the trans shift hard?
Old Aug 20, 2008 | 05:02 PM
kowboy59's Avatar
Car: 88 iroc-z z-28
Engine: 383
Transmission: th400
10 inch. its a inbetween shift.
MSRed91Camaro
Oct 6, 2015 01:56 PM
amcnellis
Sep 16, 2015 04:16 PM
Fronzizzle
Sep 8, 2015 12:10 PM
rjcme
Sep 5, 2015 01:23 PM
