Any difference between a 2WD S10 700R4 and ours?
Old Aug 18, 2008 | 08:55 PM
Ed1LE's Avatar
Car: 91 Firebird 'vert, 91 Formula
Engine: 5.7, 5.0
Transmission: T56, T5
Axle/Gears: Auburn w/ 3.73's, 3.42
I have a lead on a decent 700R4 out of a 2wd '92 S10. Stock converter, rebuilt with a B&M shift kit & billet servo. Any difference in case length or anything? Don't think there is but thought I'd ask to see if someone knows for sure while I do some research. Mines spent and figured this is a good opportunity to move up to a 30-spline shaft as well.
Old Aug 18, 2008 | 10:20 PM
WIll36's Avatar
Car: 88IROC, 91Z28 + parts cars
Engine: 355, 408
Axle/Gears: 3.42 LS1, 9" w/ 4.56 and spool
Re: Any difference between a 2WD S10 700R4 and ours?
I know the cases are the same but you may have to change the tail shaft depending on the speed sensor configuration. Also see if there is a K stamped on the case those are the stronger casings
Old Aug 19, 2008 | 06:24 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Are the tailshafts interchangable between 82 & 92?
Old Aug 19, 2008 | 08:33 AM
WIll36's Avatar
Engine: 355, 408
Yes and no the length is the same but a 82 will have a speedo bullet for the cable and a 92 will have a VSS. If you have to swap the tailshaft housing its no big deal it should take you about half an hour if you've never done it before
Old Aug 19, 2008 | 09:23 AM
online170's Avatar
Car: 1987 Firebird
Engine: 355
Do they have torque arm provisions?
Old Aug 19, 2008 | 09:27 AM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
wouldnt the shifter be in a diff place to???
Old Aug 19, 2008 | 09:33 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Cool, I knew the speed sensors were different but it seems like swapping tailshafts will take care of any issues. I've swapped tailshafts on a th350 before so I should be good.
Not concerned about the torque arm mount as I plan to install an aftermarket torque arm that doesn't mount to the trans anyway.
Shifter placement doesn't matter, shift rod on trans should be the same, different linkage on the different cars takes care of that.
Old Aug 19, 2008 | 05:01 PM
WIll36's Avatar
Engine: 355, 408
Not sure if the tailshaft housings do or not but like I said earlier it's easy to swap the housing over and that is where the torque arm mounts on a 3rd gen
Old Aug 20, 2008 | 07:55 PM
Ward's Avatar
Car: 1988 GTA
Engine: 5.0 TPI
Axle/Gears: 9 Bolt, 3.45
If it's from a 4.3L it should be the same. The 2.8L 700R4 will have the 60* V6 bellhousing (but would fit a 2.8/3.1 f-body).
Old Aug 21, 2008 | 06:59 AM
Ed1LE's Avatar
Engine: 5.7, 5.0
Thanks for all of the input guys, I picked it up the other night and it has the K stamped on the bellhousing. Found it on craigslist.com and turns out the guy selling is friends with my brother so I ended up getting it for just $200.
BAMiller
Sep 14, 2015 06:38 PM
fasteddi
Sep 10, 2015 09:32 AM
NastyEngines
Group Purchases
Sep 8, 2015 10:14 AM
TheTraut88
Sep 7, 2015 05:22 PM
greenyone
Sep 2, 2015 03:39 PM
