Shift Points How to change?
Old Nov 27, 2000 | 10:09 PM
camaroracer1992's Avatar
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
I have a 1992 Camaro RS with the 700R4 trans and I am currently building a hotter motor, but the stock shift points are at around 5000 rpms due to the original 305 motor. I would like to raise the shift points to as follows: from 1 st to 2 nd 5750 rpm's, and from 2 nd to 3rd 5400 rpms. I do not want to manually shift the trans because I race and I would like to have the utmost consistancy because it is E.T. racing. Is there springs or something that I can remove like the Th 350 or is there more to it? I need help!!!! Thanks in advance.
Old Nov 27, 2000 | 10:45 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Well i don't know if your car is equipped with an elect. trans or not but i have changed the shift points on my 700R4 by changing springs and govenor weights. This changed the shift points the same amount in all gears though.
-Auggie-
PS: I bought my govenor shift kit from B&M.
Old Nov 28, 2000 | 01:28 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
Doesn't the chip take care of that? I thought it did, if it does, drop Ed Wright (Fastchip.com) a line at http://www.fastchip.com
he'll hook you up with something
Old Nov 28, 2000 | 09:20 AM
Car: 1992 Camaro RS
Engine: 355
Transmission: th400
Axle/Gears: 3.89
Auggie, was the recal kit hard to install? It is part # 20248 right? I can do this while the trans is in the car? Thanks in advance
Old Nov 28, 2000 | 02:27 PM
Auggie's Avatar
Well the part# on my B&M shift kit is #20236 but i bought that kit in 84 or 85 so they may of changed the no. This kit works for TH-350,400 and 700R4. I am still useing this kit. I wrote down the specs. for my 84 Z28 and they are as follows for a 6000 rpm shift point.
Weights = #2 & #5 = 18.4 grams
Springs = Purple & Red
I also made a note that -(1) gram increased the rpm 400. If you had a gram scale you could raise your shift points without a kit. You can do this mod with the trans in the car but it is tight. To make it easier i remove the trans crossmember. Takes a little longer but you can do a better job. I put RTV on the gov. cover just to be sure. When you remove the gov. cover have a small drip pan for a small amount of ATF.
-Auggie-
maroe624
Apr 16, 2017 08:29 AM
Thornburg
Aug 25, 2015 01:46 AM
crazynights
Aug 21, 2015 06:53 AM
gwade12
Aug 8, 2015 08:17 AM
