t-5 questions??? help me out..
Old Nov 27, 2000 | 01:42 PM
Fastcamaro87's Avatar
ok guys heres a few questions , i hope someone can answer for me, 1. what year did they first put a 5spd in a thirdgen. 2. what fluid type is reccomended for the 5spd, my manual says that it takes dexron 2 but my 87 had gear oil in it when i got it (used of course) and i just bought a junk yard 5 spd that has gear oil in it. also the tranny i just bought has 84z written on it, but it is definitely a borg warner 5spd, im guessing that someone at the wrecking yard was wrong, now my final question is did they make any other different BW 5spds other than the t-5 and the WC t-5?.
well thanks in advance. all info is greatly appreciated.
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Nov 27, 2000 | 01:44 PM
also will using gear oil when it says to use dexron 2 hurt anything? because i am thinking that maybe when i switched mine back to dexron when it had gear oil in it may be the reason it failed, (synchro`s are bad) should i just keep gear oil in the one i just got? or would that be bad? thanks.
Old Nov 27, 2000 | 03:07 PM
MikeS's Avatar
Well, I'm no expert on this, but I do think that all the books call for ATF in the T-5. I had never heard of that, so asked the guys who rebuilt mine when I got the car. They said that they would go half ATF and half gear oil or to go with strait gear oil. I felt safer with the 90 weight oil, so I put in strait gear oil. I can't say if that was the right choice or not, but it hasn't given me any problems. Shifter feels a little stiff on cold mornings though.
as for first year... 83 comes to mind for some reason. I think 83 was the first year for a five speed and 84 was the first for a hydraulic clutch. might want to double check that though.
Old Nov 27, 2000 | 03:14 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Mike S is correct on the years. 83-87 used the regular T5, and 88-92 used the World Class T5. The first year for TPI with a T5 is 87. Regular T5's use gear oil, while WC T5's use ATF only. They have different synchros in them that will burn up with regular gear oil. There are a couple T5 replacements, one is the Tremec, the other is the Richmond. You can also put in a T56 from a 93-97 4th gen.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 27, 2000 | 11:47 PM
so would using mobil 1 synthetic gear oil 75w90 be ok to do?
Old Nov 28, 2000 | 11:30 AM
cfabe's Avatar
I just installed a t-5 from an 86 T/A in my 82T/A. Big sticker on the side "Use Dexron-II" Does this mean that it is a world class from a later year? Or were there maybe some non-WC t-5s that used atf?
Old Nov 28, 2000 | 11:32 AM
cfabe's Avatar
Also, wanted to confirm what mike2 said about 84 was first year for the hydraulic clutch. Pretty sure on 83 being first year for t-5 also.
Old Nov 28, 2000 | 06:59 PM
merf23's Avatar
Use synthetic ATF in all of them. The bearing clearances etc are designed for it.
84 Z's came with T-5's. I have read on this board that 82's came with either a BW T10 or a saginaw, but i have never seen one in person. The T-5 is the only thirdgen 5 speed that i have ever heard of. The V8 and V6 T-5's are different, but the cases are supposed to be the same. It was offered from 83-92 with the hydraulic clutch coming out in 84 (as stated). I suggest checing the pre-load on your input shaft bearing before you install the trans, it is easy and really makes a big difference in performance and durability. I check/shim mine about every 25-30K
midge54
Sep 2, 2015 06:27 PM
transamgta87
Sep 1, 2015 07:07 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
Cacike
Aug 27, 2015 05:10 PM
redmaroz
Aug 16, 2015 11:40 PM
