Any mounting differences between 87 & 91 rear ends......
I think that I may go ahead and do the labor myself on this rear end replacement. Lets say I get a drum rear end from a 91 and I want to put it on a drum equipped 87. Will it bolt right up. Are there and differences that I need to be aware of at all. Are there any special tools that I need to do this with. Thanks.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
bsa
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
1982-2000 diffs all have the same mounting positions. Internally there have been a lot of changes but the external mounting points have remained the same.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
Car: 1986 Firebird
Engine: 2.8 V6
Just replace that rear body-to-axle brake hose with a new one.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Eric-86sc
Apr 3, 2016 03:52 PM
