2 general T-5 questions
Old Nov 30, 2000 | 01:19 AM
JJ's Avatar
JJ
1. do all 89 v8 thirdgens have the WC t-5 (I know tpi cars do, what about the tbi cars). 2. any speedo problems putting up to a late model WC ('92) in an 87 car ? TIA
87 IROC, 350/5 speed. gmpp 350, vortec heads w/some work, XE268, 1.5rr's, 650dp, rpm intake, MSD ing., ect.
89 formula, L98.
Old Nov 30, 2000 | 01:32 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, all 88-92 cars have the world class T5.
The 92 T5 will bolt right in to the 87 car, but the speedo will have to be swapped with the one already in your car. The 87 speedo is cable driven while the 92 is electronic. Its a direct swap. But you might also have to change the speedo gear on the tail shaft inside the trans, if it doesnt match up.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 30, 2000 | 02:09 PM
stingerssx's Avatar
Car: '88 Firebird Formula 350
Engine: Built 383 TPI
Transmission: Built 700r4
Axle/Gears: 9 bolt, 3.27:1 Posi
Wait, so this means that it's easy to change the speedo drive on the tail shaft from electric to mechanical? I have an '82 T/A and just bought a '91 WC T-5 and I need to keep the mechanical speedo 'cause of the speed sensor for the computer. I live in LA so I would like to not get busted by the smog police. Thanks for your input.
'82 Firebird, dead stock, 9 bolt disc rear, over 200,000 miles and still going strong, more to come...
Old Nov 30, 2000 | 02:42 PM
JJ's Avatar
JJ
Thanks . . . and what year did they switch to electric speedo.
89 formula, L98.
Old Nov 30, 2000 | 02:46 PM
Blade's Avatar
What's the "smog police" have to do with your speedo ? LOL
Americanmouse
Sep 7, 2015 12:10 PM
midge54
Sep 2, 2015 06:27 PM
Cacike
Aug 27, 2015 05:10 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
