I am getting scared,(Please Read)
Ok here is the situation. The other day coming home from school I was driving my car and I decided to pass a few cars on this long straight, So I was passing them casually doing about 90 when I see a car coming so I gun it. My car got up to about 107 and then the transmission sounded like it let go of the gear and it was like it was in Nuetral. So I let off and rolled and then put it in Nutral and then when I slowed down I put it in gear and drove off. Then I noticed when I would accelerate after that, once my car got to about 4000 rpm's it would feel like my car shifted into nutral. I didn't understand but still drove the car. Then the other morning while i was pulling out of an intersection my cars tranny just stopped working, I started to take off, got to about 6 mph and then it felt like it was in nuetral again. Now nothing works on my tranny. I put it in all the different gears and it is like it is in neutral. I smelled the AT fluid and it didnt smell burnt or anything so that is a good sign but I have no clue what it could be. I just hope that it isn't something major.
This is what I have for a car.
1988 GTA
350tpi
700r4
ANy help would be great.
Thanks in advance.
jason
Well it sounds like it IS somthing major and it cant be fixed w/out at least taking down the pan. Sounds like your clutches are fryed or it could be a simple as a stuck valve... It is in need of an overhaul though :/
92 Z28 L98 350
Ported and polished heads, ported stock TPI base, ported plenum, Comp Cams XR270HR-10 cam (lift .495/.502 duration 218/224 lobe separation 110), Edelbrock TES headers, LT4 valve springs, Crane AFPR, Flowmaster catback with LT1 style tips, MSD coil & wires.
Best ET 13.5@105 mph
"Take that auto, drop it in first, hold the brakes, stomp the gas and grin from ear to ear! :-)
http://www.truspeed.org/Members/Chev...dmondIndre.htm
92 Z28 L98 350
Car: Take
Engine: Your
Transmission: Pick
Without really being able to check it out for you, sounds like the pump may have taken a crap.
The reason I say that is, it is definatly RPM related. At 4000 RPM, it goes into nuetral, that means that your clutches are releasing. You may have cavitated air. Once you slow down, you pick up some more fluid and drive off again. Now it doesn't do sqaut, no clutches are applying.
The only other thing that would make it not go anywhere is a broken component in the tranny such as an input shaft, HOWEVER, that fact that it did it at higher speeds, and went away, rules that out. I would be seriously looking at the pump.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
South East Thirdgen
Savannah, GA
'87 Trans Am
TB Coolant Bypass,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
'97 Bonneville SSE
New2Chevy
Sep 28, 2015 12:35 AM
