Who can shift into 4th in WOT? Is the B&M kit any good?
Old Nov 29, 2000 | 10:16 PM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
Just wondering who has the B&M kit to let you shift up into 4th at WOT? Is the kit any good and how easy is it to install? I'm presuming that by managing to upshift into 4th I'll increase my top speed? Currently I'm running out of 3rd (occasionally.
Thanks for the help,
RMK
1987 IROC-Z Auto (LB9)
Black/grey with kick *** looks
Mods
None yet as I just got it Tell me what to do to it and I'll do it though.
Old Nov 29, 2000 | 10:26 PM
Auggie's Avatar
Car: 1984 Z28 Camaro
Engine: H.O. 355 NOS
Don't buy the B&M kit. Buy the kit from a GM dealer #8673948.
-Auggie-
Old Nov 30, 2000 | 01:58 PM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Yep, the B&M kit won't allow a WOT 3-4 upshift. It allows you to keep the gas almost-floored in 4th. I have the B&M one, and love it, but didn't know about the 3-4 WOT GM valve back then.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Nov 30, 2000 | 03:18 PM
JIMS406RS's Avatar
B&M makes 2 different kits, one will allow almost full throttle, and one will allow full throttle upshifts. They both suck, but the Gm part, its cheaper anyhow.
91 RS
HOTCHKISS LCA'S PANHARD AND SPRINGS.
ALL URETHANE BUSHED
SUSPENSION TECHNIQUES SWAYBARS
SUBFRAME CONNECTORS
SPOHN TORQUE ARM
KYB'S
WHITE FACE GAUGES
COWL HOOD
92 Z28 SPOILER, GRILL AND FOG LAMPS
ADMIRAL BLUE
T-56
3.73'S L/S
SPOHN LCA BRACKETS
406 DFI
SUPER RAM
AFR 190
COMP CUSTOM CAM....
Old Nov 30, 2000 | 04:55 PM
vortecfcar's Avatar
Car: '98 Z
Engine: LS1/6
Transmission: 4l60E
I have the b and m piece..........of ****! buy it if you want engine blowing downshifts at 140 or so
91 RS W/carbed 350, Vortec heads, performer rpm, Comp cams Xtreme energy 280 grind. BFG Drag radials. 3.42 posi,Corvette servoed 700r4, ****ty stock converter
13.24@104
[This message has been edited by vortecfcar (edited November 30, 2000).]
Old Nov 30, 2000 | 07:21 PM
Lostsol's Avatar
I have the B & M kickdown sleeve, and it does nothing for my 3-4 shift at all. I have adjusted my tranny all throughout the tv cables' range and nothing, I've done over 145 mph in third and still not been able to get into fourth, and this is with a transgo shift kit. I think the tranny being an 85' has a lot to do with it, 7 vane oil pump and such instead of 10 vane. Just my 2 cents, we'll see what happens when I get this 88 tranny re-built to put in.
Old Nov 30, 2000 | 07:46 PM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
I am surprised Bernard (GMTech) hasn't responded. I am the first to admit that I am "Transmissionally Challenged". But in response to "Who can shift into 4th @ WOT"? My GM SRTA 4L60 Remanufactured tranny can!
When I first got my GTA, I found out the dangerous way that my original 4L60 could not upshift into 4th @ WOT. I was passing 3 semi-trailers travelling in tight formation and just as I started to pass the 3rd semi...I found that my tranny could not upshift into 4th @ WOT...and a car was now heading towards me.
Surviving the incident and the mild heart attack afttwards, I immediately went to the dealership (where my sister works) and complained about the upshift problem. I explained the circumstances and got a free upgrade. I forget the exact fix, something like a different valve body from the Corvette or B4C trannies at that time. It definitely fixed the problem and my tranny would then upshift into 4th @ WOT.
Then I started to make some bolt-on mods and in 1995, my original tranny blew a seal. This time I got a warranty replacement GM SRTA 4L60. They explained that this had the internals from a 4L60E, in the then current 4th Gen, but with the case was 700R4/4L60 and had manual valving instead of the electronics of the 4L60E.
This tranny does everthing beautifully and better than my original tranny. After all it died blowing a seal and I was definitely not putting out any serious power with just bolt-ons. I have subsequently add a little more HP with more bolt-ons and has had far more abuse than my original tranny. I suspect it would have already failed again if I had just had it rebuilt.
Hopefully, GMTech will come by and tell you the exact part you need to fix your 700R4/4L60 so it can upshift into 4th @ WOT.
PS: If I ever blow my current tranny, I would get another GM SRTA 4L60. I figure it would even handle more power since the current 4L60E can handle the power of the LS1.
[This message has been edited by Glenn91L98GTA (edited November 30, 2000).]
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
camaro11j
Sep 19, 2018 08:49 AM
TreDeClaw
Aug 14, 2015 06:58 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
dhonda200
Aug 11, 2015 11:50 PM
