quick question on t5 swap and ecm
Old Aug 23, 2008 | 02:38 PM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
jsut a quick thing i did some reading and just want confirmation
just wiring to the stock ecm harness is all i would have to do to tell it wheich gear its in and all that fun stuff
i shoudlnt have to change the ecm or prom
but if i installed a shift light in teh gauge cluster how will the ecm tell it to light up?
Old Aug 23, 2008 | 02:43 PM
driver101's Avatar
Car: 91 rs,1 92 rs,92 b4c/1le
Engine: 5.0tbi,5.7 tune port/5.0tpi
Transmission: 5spdx2 and t56
Axle/Gears: 3.08,3.73,3.42
Re: quick question on t5 swap and ecm
in order to use the factory hift lite you need a 5spd prom or it will light at the wrong times. as far as wiring goes you need to adapt the neutral safety to give you backup lites.
luke
Old Aug 23, 2008 | 06:34 PM
iansane's Avatar
Car: '91 TA vert
Engine: turboLSx
There's nothing inside a t5 to tell your ecm what gear it's in.
Old Aug 23, 2008 | 06:37 PM
Bobby_80s's Avatar
Axle/Gears: no idea
right but im jsut concerned if i wanted a shift light to work in my gauge cluster
i can shift from listening to the rpms jsut curious if i can keep the ecm and prom as is or if i need to delete the torque conveter switch on the prom or beok by jsut leavign it disconnected
ok thanks driver 101
$750 L98
Feb 1, 2025 02:25 PM
91 SrS
Oct 7, 2015 04:32 PM
92projectcamaro
Sep 29, 2015 07:07 PM
IROC ZELLER
Sep 29, 2015 03:00 PM
dbrochard
Sep 7, 2015 09:41 AM
