28spline rear question
I have a rear at home with only one axle.
Its a 3:42 with posi and one 28spline axle. The other one cracked in half.
And.....I have the driverside 28spline axle. Would I need to buy the passenger side replacement. Or could I find another 28spline drivers side. In other words are they interchangeable or designated for a certain side?
and.....I was wondering ....could I use just the housing from an old 26spline rear I have sitting at home for this project?
92 Formula
305 TPI 5speed
1LE package
Mods: SLP headers,SLP catback,SLP air foil,ported plenum,K&N, Crane AFPR (47psi),MSD6AL, MSD wires, AC DELCO cap/rotor/plugs, Bosch O2sensor, 3:73s,JET fan switch, Macewen white face gauges, Intellitronix Digital Gauges
92 Formula
305 TPI 5speed
1LE package
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Yes, the housings are the same, just the internals are different, among thirdgen 10-bolts.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
1991 Camaro Z28
13.25 @ 107.18 MPH
Southern California
Car: 1986 Firebird
Engine: 2.8 V6
I believe the axleshafts are interchangeable per sides; when I had mine out to change my bearings & seals (routine overhaul) I don't remember seeing any difference between the driver's side or passenger side.
There might've been a difference overall between the wheel flange of rear-disk-brake axleshafts and rear-drum-brake axleshafts. I think one flange (where the lug bolts are) was thicker than the other... if that matters for your applications.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
OK cool. I just bought a 28spline axle for $30shipped from a guy I know. Do you think the carrier and gears will fit in the 26spline housing?
Arent the axle housings a different shape?
92 Formula
305 TPI 5speed
1LE package
92 Formula
305 TPI 5speed
1LE package
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
The axles are the same length on each side. A 28 spline carrier will fit in a 26 spline housing.
I almost used my 26 spline carrier when I went to 28 splines. I had the 28 spline side gears but found the hole in the carrier for the 28 spline axles was just a little to small. I drilled it out to 1 1/4" for it to work then found a 28 spline carrier the next day.
Aftermarket 28 spline axles (better than stock axles) for third gen can be found at www.drivetraindirect.com part #KAC7-A7 for $125 each.
Stephen's racing page
87 IROC-Z Pro ET Bracket Race Car
383 stroker (carbed) with double hump cast iron heads and pump gas
454 Big Block buildup now in progress for the 2001 racing season
Best results before the 383 blew up
Best ET on a time slip: 11.857 altitude corrected to 11.163
Best MPH on a time slip: 117.87 altitude corrected to 126.10
Best 60 foot: 1.662
Racing at 3500 feet elevation but most race days it's over 5000 feet density altitude!
Member of the Calgary Drag Racing Association
87 IROC bracket car
91 454SS daily driver
95 Homebuilt Harley
Best 60 foot: 1.662
87 IROC bracket car
95 Homebuilt Harley
