Ditched the computer... now it shifts hard!
Old Dec 3, 2000 | 01:24 PM
Biochem's Avatar
Car: 2002 SOM z28
I just bypassed the computer and installed a Holley carb. I got the bracket Holley said I had to have for the 700R4. My TV cable is pulled all the way out and it has a little play in the line. It shifts at 3000 rpms, but really hard, it every gear. I don't mind the 3000rpm shift point, but the fact that even in first it does it and pounds into 2nd... even at part throttle. Almost like I am manually shifting from 1 to 2 then to 3...
Also, when I do rev up to say 3000 in 3rd, then it slowly goes down as the car slows down, it doesn't drop immediately. Is this normal?
1984 z28 w/ a 357 cu in. monster engine which is looking like the posterchild for Edelbrock... all the suspension stuff... 9-bolt posi disk is in... K&N filter... 93 octane...
-=ICON Motorsports=-
Old Dec 3, 2000 | 06:00 PM
ede's Avatar
ede
only thing i could see is trying to readjust the tv cable again. that's the only thing you messed with isn't it?
-=ICON MOTORSPORTS=-
1st & 3rd
Old Dec 3, 2000 | 07:31 PM
Bort62's Avatar
Mine does the Same **** after Ditching the Comp Carb.
pretty Sure i got the Tv cable Mal-adjusted
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Old Dec 4, 2000 | 08:05 AM
Biochem's Avatar
Car: 2002 SOM z28
Well, I cannot adjust it any more loose because the bracket is so far away from the stud that it is all the way out. I did try to tighten it a little and the shift points rose to about 4000, but it was still hard and reving the same (as if it was locked up in all gears?).
Old Dec 4, 2000 | 01:06 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Can't say this from hands-on experience, but I believe the length of the arm on the Holley is shorter than on a TH700R4 q-jet (for instance). So, the Holley is not pulling the cable as far, and therefore the adjustment will not be proper.
There was a post somewhere recently on this, with pictures.
82 Berlinetta, orig V-6 car, now w/86 LG4/TH700R. 2.73 unlimited slip. Cat-back from '91 GTA, Accel HEI SuperCoil. AMSOIL syn lubes bumper-to-bumper. Daily driver, work-in-progress (LB9 w/ZZ3 cam, TBD heads, exhaust, paint, etc.).
57 Bel Air, my 1st car. 0.030 over 396, Weiand Action+, Edelbrock 1901 Q-Jet, Jacobs Omnipack, 1-3/4" headers, TH400 w/TCI Sat Night Special conv & shift kit, 3.08 10-bolt, AMSOIL syn lubes bumper-to-bumper. Best 15.1 @ 5800' Bandimere. Daily driver while Camaro was being put together.
Old Dec 4, 2000 | 07:40 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
I would definatly say its with the TV cable, but since I have never dealt with the problem, I can't really tell you what to do.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Old Dec 5, 2000 | 07:02 AM
kream-'s Avatar
thats crazy my car does the exact same thing ever since my zz4 swap and i still havn't figured it out.. i've basically given up and im just being lazy about putting my new rebuilt tranny in...(although im trying to wait untill at least spring)
any other ideas what this may be?
(btw i still have tpi and all computer stuff)
17 from Wichita, KS (previously newbieZ28)
1988 Iroc-Z ZZ4 tpi, ttops, 50k miles on chassis (edelbrock tes, stock tpi) free mods etc coming soon after first 1/4 times!
1985 Z28 LB9 option [STOLEN!] Click here to see
http://thirdgen.bawx.org
K.I.S.S - Keep It Simple, Stupid.
AmpleUnicorn88
Interior Parts Wanted
16
Nov 29, 2015 05:45 PM
customblackbird
Oct 1, 2015 04:30 PM
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
Breazlan
Sep 25, 2015 11:20 AM
TheTraut88
Sep 7, 2015 05:22 PM
