Zexel Torsen~
Old Nov 30, 2000 | 11:23 AM
Bort62's Avatar
Zexel Torsen~
Wich Rear End is it that Accepts the Zexel Torsen POSI from SLP ?
10 Bolt with 26 or 28 Splines ?
And Wich year cars Came with this, My 85 is a 10 bolt, But How Many spline axles Do I have ?
85 Z28 - Daily Driver
60 Ranchero - Project ( Money Hole )
Old Nov 30, 2000 | 11:31 AM
Dana92RS's Avatar
It fits a 10-bolt with 28-spline axles. I'm pretty sure your car has 26-spline axles as I don't think they switched until '89. I think you could just get some 28-spline axles and they will work, maybe someone here has some for sale for cheap.
Old Nov 30, 2000 | 12:53 PM
fb305svs's Avatar
Car: 1991Firebird T/A
Transmission: Modified Viper t-56
Axle/Gears: dana 44, 3.55
umm didnt they switch in 87 to the 28 spline axels in the 10 bolts??? just thought that was the date, i might not be comepletely correct
Steve
Old Nov 30, 2000 | 01:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Everything I've seen says they switched in 89, but you'll still have to check, because it wasnt a full switch, it was a phased in switch. Meaning some cars had 28 and some cars had 26.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Nov 30, 2000 | 01:25 PM
Bort62's Avatar
Allright, But all I would need is Some new/ used 28 spline axles ?
Sounds like a very Cost effective way to get Posi ? What would Instlling it detail ?
Old Dec 5, 2000 | 11:00 AM
ws6transam's Avatar
Car: 1984 Trans Am WS6
Engine: Minirammed 385, 396 RWHP
Axle/Gears: 3.73 Moser 12-bolt
Here's the details for you.
How to build a better 10 bolt
I built a Toren equipped 10 bolt from my 1984 axle housing and it works great.
Daniel Burk
http://www.isthq.com/~dan/fcar.html
'84 Trans Am WS6/L69
KB SFC, Moser axles, Torsen Diff. PST suspension, Braided stainless brake lines, Koni struts, 11-inch rear disks,Spohn Adj. torque arm,
Ported 305 heads w/1.94"intake valves, Comp Cams XE262H, Griffen alum. radiator,
Turbine Technologies 2500 stall converter, underdrive pulleys, Crane Hi-6 & more.
1.05g skidpad verified.
New best E/T! 14.039 at 100.82 MPH in 41 degree air at Stanton, Michigan.
Orr89RocZ
Oct 7, 2015 12:47 PM
92fire-audio
Aug 27, 2001 01:40 PM
ws6formula89
Jul 26, 2001 07:13 AM
Cliff92Z
Aftermarket Product Review
Mar 29, 2001 08:15 AM
theformula
Oct 18, 2000 12:46 AM
