Flywheel
Old Dec 5, 2000 | 12:35 AM
Fastcamaro87's Avatar
Flywheel
ok im gonna be doing my tranny and clutch change after work, a few people have told me i have to have the flywheel resurfaced. is there a way i can do this myself? what materals do i need? also im only changing the clutch because i will have the tranny out, so as far as i know everything should be in good shape, what kind of prep should i do to the flywheel before installing my new clutch?
thanks..
87 IROC-z 305 TPI 5spd Borg warner 9-bolt 3.45 posi 4 wheel disc,8.8 Accel wires , bosch platinum +4 plugs,gutted air box,k&n oil filter,synthetic oil 10w30
Old Dec 5, 2000 | 08:46 AM
lock's Avatar
Car: 86 IROC-Z
Engine: Superramed 355 w/ intercooled T72
Transmission: T56 -=- www.iroc-ss.com
The cost of getting one done is usually only $20-$30. You could probably clean the surface on your own but you wont be able to make sure its flat. Heck I just took one that was covered in surface rust and ended up with a flywheel that looks brand new. Not wroth the hastle and I dont see how you can do it yourself anyways for only $20.
Mark Lock
- 86 IROC-Z - Torn down for 383/SuperRam T56 setup
- -= IROC Online =- - The site dedicated to the IROC-Z
Old Dec 5, 2000 | 01:19 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Lock is correct, get your flywheel resurfaced at a machine shop. It helps ensure good friction between the flywheel and your new clutch. And most places charge only $20 to do it.
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 5, 2000 | 01:24 PM
the only problem is that im using my freinds garage, and his lift, and he is a commercial garage, so i have to do it all tonight, and all the places i know of that resurface flywheels close before 6:00 and that is when im going to start workin on it, because that is when he closes his doors to customers.so im trying to find a way to do it myself. because he has to have all his bays open for tommorow.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
Vincent135
Sep 28, 2015 10:50 PM
mfp189
Sep 27, 2015 09:25 AM
monte87cortez
Sep 26, 2015 08:10 PM
el_muerte
Sep 16, 2015 12:01 AM
