700R4 and B&M HAMMER SHIFTER
Old Aug 26, 2008 | 12:43 PM
RED PIG's Avatar
I have a 1986 Camaro that has a 700R4 trans with a B&M hammer shifter. I am going to make it a drag car only. On the B&M instructions it says to remove a bolt so it can be used to shift into 4th or OD. Can I put the bolt back in the shifter and only have 3 forward gears to shift and the rest of the shifter will be neutral reverse and park and omit the OD shift.
Old Aug 26, 2008 | 09:27 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
Re: 700R4 and B&M HAMMER SHIFTER
its possible, but why?
leave the capability for fourth and just dont use it.
i think what the instructions provide is a way to "cut out" the 6th position, so what you would end up with is no "p" and n(d)d321 working... not good.
Old Aug 26, 2008 | 09:35 PM
RED PIG's Avatar
no green
Jan 9, 2016 09:22 PM
ndndndnd
Sep 28, 2015 08:00 AM
