T5 situation and resulting questions
Old Dec 7, 2000 | 04:25 PM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
Transmission: Borg Warner 5 speed
Okay,when in neutral there is a whirring/chattering sound, this is normal right? When I push on the clutch it goes away. Normal, right? When I let off of the clutch, the chattering sound comes back. Why? What is it that makes that chattering sound? That is the sound I've been experiencing in my first gear lately, if you've happened to glance through my other posts. What do you think I should check? an someone also please explain the different bearings to me? (Pilot, and throwout bearings only please.)
Thank You!
Brandon
Old Dec 7, 2000 | 04:36 PM
kjgroen's Avatar
Car: Trans Am
Engine: L69
Most likely it is the throwout bearing making the chirping noise. the pilot bearing is in the end of the crank. Kevin
Old Dec 7, 2000 | 07:13 PM
merf23's Avatar
The whirring is the spinning of the gears in the trans. The pilot bushing is in the back of the crankshaft...the input shaft rides in it; There is relative motion at the pilot/input shaft when the clutch is disengaged (pedal down). The throwout bearing is what disengages the clutch throught the pressure plate. These sometimes make noise when the clutch is in and other times when it is out.
Old Dec 8, 2000 | 01:05 AM
90Iroc's Avatar
Car: 1990 Iroc/Z
Engine: LB9 305 TPI
I figured out a way to describe the noise, sort of. Does anyone remember the Chipmunks? It sounds like the chipmunks laugh but slowed down a bit. That's the noise I'm getting in first gear on top of this neutral noise.
[This message has been edited by 90Iroc (edited December 08, 2000).]
chazman
Aug 28, 2018 03:25 PM
db057
Sep 4, 2015 07:57 AM
chazman
Aug 22, 2015 02:01 PM
redmaroz
Aug 16, 2015 11:40 PM
jahblah
Aug 12, 2015 05:54 PM
