Trans wont shift out of first
Old Aug 28, 2008 | 11:06 AM
SpeedMetalT/A's Avatar
Car: 87 Trans Am
Engine: L98 350 w/carb
Transmission: TH350
I have an 87 Trans am with a 700r4 trans. It will go into all the gears while stopped, but once your going forward in drive it wont shift out of 1st and if it tries to it will go into neutral and then go back again. I've tried manually shifting it to the next gear starting out in 1st and that wont work either. The TV cable is connected and adjusted properly and the vacuum line from the trans to the carb is also connected. I'm thinking the front pump might be going, that the servo is shot, or there's something wrong with the valve body. I don't have alot of experience with transmission problems like this though so does anyone have any ideas as to what the problem is?
Old Sep 2, 2008 | 12:50 AM
antoine's Avatar
Car: 1988 camaro z28,1997 camaro lt1
Engine: 355 afr 195 heads,tpis big mouth
Transmission: 700r-4 built by me 3-4 z pack
Re: Trans wont shift out of first
check the governor gear teeth and what vacuum line are you taking about from the transmission
Old Sep 3, 2008 | 10:14 PM
performabuilt's Avatar
There is no vacume line to a 700r4 . But agreed check you gov gears first little meta round cover toward rear of trans. If its not that you likley will be needing a trans
Old Oct 30, 2008 | 01:49 PM
Car: 87 Trans Am
Transmission: TH350
Thanks I recently got a used trans with 30k on it and installed a TCI trans kit and billet servo. Unfortunately the I didnt put the snap ring for the boost valve in far enough so it shifted funny and had no reverse at first, but all is good now.
Old Nov 2, 2008 | 07:38 AM
Brando5641's Avatar
Car: 1998 Trans/Am, 1989 RS Camaro
Engine: LS1, LQ9 6.0
Transmission: 4L60E, 4L60E
Axle/Gears: 2.73, 2.73
the cable was to tight.
1992 Trans Am
May 10, 2023 07:19 PM
maroe624
Apr 16, 2017 08:29 AM
mizz0313
Aug 12, 2015 06:45 AM
dhonda200
Aug 11, 2015 11:50 PM
