overfilling trans fluid...is it good for racing?
Old Dec 10, 2000 | 11:38 AM
Fastbird's Avatar
Car: 1991 Formula
Engine: 434
Transmission: PG
Axle/Gears: 4.33
I read an article that recommended overfilling the trans fluid by 1 quart and using a deep pan to reduce the pickup from sucking in air and fluctuating the line pressure on harsh take offs (i.e. sub 12 second race cars) does this sound right? If so, who makes a good pan?
Steve
Old Dec 10, 2000 | 05:50 PM
ede's Avatar
ede
if you ran a deep pan you'd have to run more atf. if you mean to go above the full mark i've never heard of it and don't think i'd do it. if i had problems with shifting then i might start looking for a fix.
ICON Motorsports
1st & 3rd
Old Dec 10, 2000 | 07:57 PM
GMTech's Avatar
Car: Take
Engine: Your
Transmission: Pick
No, its not good for racing, but it is good for tearing your stuff up. Its just like overfilling the engine. When the oil level contacts rotating parts, it gets "whipped up" with air and becomes foamy. That air displaced oil and is a sure fire way to really damage some internal components. If you run a deeper pan (as if our cars don't sit low enough) you will need extra fluid, but NEVER go above the "full" mark on the dipstick.
As for starving the filter on acceleration, the filter rests on the bottom of the pan, I doubt that accelerating hard will cause that much fluid to leave the pan.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
Reddeath210
Oct 6, 2015 08:20 AM
gta power
Aug 13, 2015 06:15 AM
mizz0313
Aug 12, 2015 06:45 AM
