5x120 and 5x126
Car: 1991 Trans Am GTA
Engine: 502 Ram Jet
Transmission: TKO600-racing gears
Axle/Gears: 12 Bolt Moser-33"axles-3.91 ratio
5x120 and 5x126
Are those dimensions same for bolt pattern?? Can I use 5x120 wheel on my 5x126 bolt pattern??
Car: 86 Trans Am
Engine: 408 stroker sbc
Re: 5x120 and 5x126
if that is in fact your bolt spacing, 120.65 is stock, they may "fit" on the studs, but they are not correct, and can overstress the lugs and possible cause failure. my 2 cents, get the right pattern no point messing with something close
actually correct that, they wont fit, they are 6mm different, thats about a 1/4 inch
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: 5x120 and 5x126
yep, fbody is 120.65 and 120's will fit just fine. thats .025" difference.
Car: 1989 GTA
Engine: Future: LSX Turbo
Transmission: built T-56
Re: 5x120 and 5x126
yep fits just fine had mine on two years and no problems. It WONT cause a problem, just make sure they are torqued well and checked over after about 20 miles of driving.
