5x120.65 to 5x120 spacers!!!
Hi,
After getting a makeover of my camaro 91 I am in dying need for some new 18" wheels. Problem is that wheels which fit my car are of 5x120.65 and the wheels I want are 5x120.
Since 5x120 would not fit I guess I need some spacers/adapters.
Question is, are there any spacers which can convert from 5x120.65 to 5x120 ???
Thanks for all help.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: 5x120.65 to 5x120 spacers!!!
They would be adapters and at least 1.25" thick, they are available. If the wheels already have a favorable offset, they can be redrilled to the proper 120.65. Search pcb correction and you'll find my thread and whats needed.
Car: `86 SS / `87 SS
You really should check out //<86TA>>\\ wheel redrilling mod first.
Well, after you figure out what offset wheels you're considering. There are so few 120.65 with the right offset.
Search wobbly nuts too.
Thanks !
Checked out the video on wobble bolts and the guy in the video is using these bolts on a hub with 5x112 with wheel bolts 5x114.2.
Can't I use these bolts on my camaro 5x120.65 and wheels with 5x120 if the bolt holes are big enough ??
Car: 86 Trans Am
You can use them, but the wheel has to be hubcentric or used with hubcentric adapters to center the wheel on the hub be for tightening the bolts. The wobbley nuts work ok but are not ideal
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Wobble nuts aren't cheap, either.
