Help! My 4L60 trans is POSSESSED!!!!
Old Dec 11, 2000 | 12:18 AM
Black Missile's Avatar
Every time I shift into and out of reverse gear, the trans shifts rather harshly making the whole car lurch forward slightly.
Except for reverse gear, all other gears including park shift smoothly when manually selected from a standstill.
I'm thinking it might be a bad reverse gear boost-valve. If it is, do you need any "specialized" tools to R&R the front trans oil pump to access the valve?
The Helms manual states that you need a end-shaft(?) puller and some kind of alignment(?) tool to align the oil pump cover assembly back into the trans when re-assembling. Do you have to be a trans shop to get these tools?
Thanks.
1989 Firebird GTA: black on black 5.7 liter (N10 dual exhaust) with T-tops and leather.
Old Dec 11, 2000 | 12:36 AM
IROCracer's Avatar
Sounds like your F-body has been f*cking my ex's M*****G. Her POS has the same problem, and I never figured that thing out.
Good luck,
Kelly
If you've gotta fix it, fix it better than stock.
1992 Trans Am
May 10, 2023 07:19 PM
Hawk312
Aug 22, 2017 08:55 PM
C409
Sep 1, 2015 03:42 PM
Hello, Michael
Aug 20, 2015 03:19 PM
mizz0313
Aug 12, 2015 06:45 AM
