TH 350, what fitting is in and which is out
Old Dec 9, 2000 | 05:24 PM
ede's Avatar
ede
i asked before but didn't get any where. the trans isn't in the car right now. i need to know to run a braided line to a oil filter and then the trans cooler and another line back to the trans. the in and out part is important to the oil filter. thanks.
ICON Motorsports
1st & 3rd
Old Dec 9, 2000 | 08:10 PM
CamaroMike's Avatar
I just struggled with this on my 700R. I wanted the tranny oil to enter the top of the radiator and exit the bottom. I pulled the line off of the top of the radiator and started the car. I was hoping oil would run out of the top line. Much to my disliking the oil shot out of the top of the radiator and all over my engine. Tried to switch the lines at the tranny and due to the bends the lines could not be swapped. So the output of the trans goes into the bottom of my radiator. The only resistance to flow is the weight of the fluid column in the radiator. I just plumbed my tranny cooler so the fluid exits the top of the radiator into the top of the cooler and is returned from the bottom of the cooler to the top line. If your car follows suit your filter input line will need to go to the top of the radiator and the return line to the top line. If you are not sure take the top line out put a nipple in the radiator and use a brake line fitting to attach a nipple to the top line. Then you can put two hoses on the nipples place them in a jar and see which one the fluid comes out. Thats the pressure line. The only thing I ask for this advice is to tell me your results. I have always thought the fluid should go into the top of the radiator so gravity could help flow. I would like to know if my car is just weird or just like every other stock thirdgen.
Please respond.
84 Camaro ZZ4 with HOT cam. 1.88 60' (12.98 @ 105MPH E.T.)
Other Mods: You name it and I have probably changed it.
91 Firebird 5.0L TBI
ASE Certified Auto Tech
LIVE AND DIE BY THE ALMIGHTY BOWTIE!
Old Dec 10, 2000 | 09:26 AM
ede's Avatar
ede
i'm using a permacool oil/trans cooler. aftermarket oil filter kit and braided stainless lines. nothing stock about it and i'd like to know before i put it all together and in the car. there's no cooler in my radiator.
ICON Motorsports
1st & 3rd
[This message has been edited by ede (edited December 10, 2000).]
Old Dec 10, 2000 | 10:35 AM
CamaroMike's Avatar
Attach both braided lines to the trans and see which one fluid comes out of when you start the car. Super Easy!
Old Dec 11, 2000 | 01:21 AM
Bort62's Avatar
CamaroMike
The Fluid Runs UP the Cooler in the Radiator, that is to Say that the Pressure Line is the lIne On the Bottom.
Ede, as for On the tranny, I dont Know
Turn the Pump By Hand a bit, See what Happens
60 Ranchero - Project ( Money Hole )
85 Z28 LG4 - Daily Driver
**Mods**
MSD Superconductors
14" Open Element
KYB all around
Keith5
Aug 27, 2015 04:37 PM
theurge
Aug 21, 2015 12:46 PM
wruiz
Aug 13, 2015 09:07 PM
armybyrd
Aug 10, 2015 09:23 PM
milk
Aug 10, 2015 06:26 PM
