REAR END QUESTION
Old Aug 30, 2008 | 04:22 PM
neverdone's Avatar
Car: 1989 formula
Engine: small
REAR END QUESTION
ok guys i got a question on a rear end... i have a 1989 formula with a stock gear in it what ever that may be.. my question is i bought a rear out of a 4th gen with a 3.73 richmond would i be able to jus take the posi and gear out of the 4th gen and put it in the rear of my formula????
thanks
Old Aug 30, 2008 | 04:27 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
Re: REAR END QUESTION
just swap the entire rear...urs probably has 26 spline axles and the newer one would have the 28 spline axles. and if u are not familiar with rear ends i dont recomend trying to swap the posi and gears yourself...the whole rear end will bolt right in and be a little stronger...the only thing is its slightly wider so u would need different rims or u can run newe style vette/fbody rims back there with no spacers...
Old Aug 30, 2008 | 05:39 PM
neverdone's Avatar
Car: 1989 formula
Engine: small
i already have welds for the back and i dont feel like buiyin another new set... i dont have a prob changin it no big deal really i got a deal on the rear but it doesnt have the pin that holds the axles in nor does it have backing plates on it so that where i sit at
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
hectre13
Aug 26, 2015 08:17 AM
AkDrifted
Aug 17, 2015 07:45 PM
BlackBoulder
Aug 11, 2015 11:15 PM
