Rebuilt trans leaking horribly
Old Aug 31, 2008 | 01:32 AM
sweetaq's Avatar
Car: 1982 Z28
Engine: 385ci w/carb
Transmission: TH350 w/3200ish Stall
Axle/Gears: 10 bolt :( 3.23 gears w/ posi
I just installed my rebuilt th350 that I paid a local guy who came recommended by some racers at the local track and it is leaking pretty bad. I installed it with the 385 I built and the motor fired right up and I noticed a broken stream of trans fluid coming from the front of the trans. I had a buddy add 2 quarts of fluid during the course of the break in so I wouldn't have to abort the flat tappet break in. After I started it again I looked under and saw it is coming from the part where the torque converter goes in and around the front pump. How hard is that to fix my self so I don't have to drive an hour to the guys shop to drop it off and wait maybe a week to get it back. I called the guy today at home but didn't get a response yet. I have no trans experience so is this something I should not even try to tackle? All I did was install the torque converter, is there any way I caused this, I don't see how. The converter went in smooth and installed all the way back with three clicks.
Thanks guys
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Reddeath210
Oct 6, 2015 08:20 AM
355sbcTPI
Aug 19, 2015 04:38 PM
mizz0313
Aug 12, 2015 06:45 AM
Exxon Limited
Aug 9, 2015 08:13 PM
