rearend disc posi conversion (HELP)
Old Dec 14, 2000 | 09:46 PM
Jeff Hauge's Avatar
Does anyone know the rear axle code for a 92 Camaro 10 bolt 3.73 posi rear? I am about to purchase one, but I want to make sure it is what it is supposed to be. I also want to know weather or not to get the prop. valve and the master cylindar from the donor (disc rear) car or to just get an adjustable prop. valve from summit. How hard is it to install an adjustable valve?
Old Dec 15, 2000 | 09:35 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Did you mean 92? I don't think there was a 3.73 gear in any f-body in '92; I believe that stopped in '85. Did you mean '82? Er, wait, I don't know if '82's had 3.73's either.
What year is your car? You will always need to get the prop valve from both cars. 82-88 and 89-92 had different requirements for master cylinders. Let us know.
Anyone got that 3.73 info?
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 15, 2000 | 11:18 AM
Jeff Hauge's Avatar
My car is a 92 and the rear I am going to get is from a wrecking yard. I have only talked to the guy over the phone and he claimes that it is a 92 10 bolt with posi disc and 3.73 ratio.
Old Dec 15, 2000 | 12:08 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Its possible the previous owner swapped in a 3.73 gear, but it didnt come stock in 92. The highest available stock was 3.42. The only way to know for sure is to pull the cover and look at the ring&pinion for the numbers, or to spin the wheels and count the number of times the driveshaft turns. (or the yoke if there is no driveshaft)
1991 Camaro Z28
5.7L 5-Speed (originally 305)
13.25 @ 107.18 MPH
Southern California
Member: SoCal 3rd Gen F-Bodies
Webmaster: SoCal F-Bodies
-=ICON Motorsports=-
Old Dec 15, 2000 | 12:44 PM
Jeff Hauge's Avatar
does anyone know what years were avaliable with 3.73 posi disc?
Old Dec 17, 2000 | 08:12 AM
Zee's Avatar
Zee
I know 83-84 L69 5-Speed cars came with 3:73's and optional discs. At least mine did.
[This message has been edited by Zee (edited December 17, 2000).]
jrdturbo
Mar 31, 2016 02:58 PM
92projectcamaro
Dec 8, 2015 12:25 AM
loud91rs
Oct 5, 2015 10:05 PM
92projectcamaro
Sep 29, 2015 07:07 PM
indygene
Sep 26, 2015 11:21 AM
