Is a 96 700R4 the same as a 98 700r4?
Subscribe
Dec 11, 2000 | 03:52 PM
Is a 700R4 a 700R4 reguardless of the year? The one I want to replace my broken one with in my 89 IROC with is from a 96 Conversion van. Will it fit? Thanx.
Reply 0
Dec 11, 2000 | 04:18 PM
If it's a 4L60, it will work, but for a 96 it might be an electronic 4L60E, which won't.
1984 Camaro Z28 Astral Silver w/ 2 1/2" cowl induction hood
Engine: Decked 383 cid 4 bolt w/ oil cooler, 9.6:1 compression, ARP fasteners, 600 cfm Performer carburetor, Torker II intake, Performer RPM Heads, XE268H cam, Magnum roller tip rockers, MSD6AL ignition, Blaster2 coil, recurved HEI distributor
Exhaust: Terminator headers, Custom 3" TIG welded stainless exhaust, Twister muffler
Transmission: 4L60 w/ Corvette servo, .500 boost valve, TransGo 7-CS clutch springs, 700 PKH pump rings, 700-2 reprogramming kit, Borg-Warner High-Energy frictions & bands, 2400 RPM lockup torque converter
Drivetrain: 2.73:1 limited-slip Dana 44 w/ disc brakes
Tires: Front P225/50VR15 Rear P265/50VR15 Eagles
Reply 0
Dec 11, 2000 | 10:17 PM
How can you visualy tell the difference between the two? Thanx....
Reply 0
Dec 13, 2000 | 01:32 PM
I believe 1993 was the last year for the normal, non-electronic 4L60/700R4.
I'd imagine the 4L60E should have an extra electrical connector somewhere.
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Reply 0
Dec 17, 2000 | 09:00 PM
The 4L60E has a round (about 1.75" diameter)electrical plug on the passenger side.
Reply 0
Dec 17, 2000 | 09:35 PM
Yes, '93 was the last year for the 4L60. And only the Fbody got them. The trucks and other RWD got the 4L60-E in '93. One big difference is the large electrical connector on the PASSENGER side, the deletion of the TV cable.
As for your question, '96 used slightly different valvebody (mainly for the TCC circuits and some others), the many of the '98s have a full faced bellhousing, and a few other differences.
If you live in Southeastern US, check us out!
South East Thirdgen
ASE Master Tech + L1
Savannah, GA
'87 Trans Am
S/D TPI retrofit including functional PassKey, 22# injectors,
JET AFPR, Ported Plenum,
TB Coolant Bypass,
SSM SFC, Boxed LCAs,
8mm Accel wires,
Flowmaster Exhaust,
16" GTA rims,
Corvette Servo,
KYB Shocks
-->14.97 @ 94.9 MPH<--
'97 Bonneville SSE
Reply 0
Subscribe
