Got the rear end stuffed back in there
Old Dec 19, 2000 | 06:13 PM
irocbsa's Avatar
Well, finally got the thing done. I took two days. Damn near brok my arm trying to get some of those bolts off. Thanks to TomP and the others that helped out. Anyway, now a noise is coming from back there. It sounds like tss,tss,tss,tss and increases with engine vehicle speed. I've checked to see if anything like the ebrake cable was touching moving parts but no such luck. Had the brakes refurbished like a pro so it can't be that (it was making the noise before I took it to them) What could it be? BTW, those 3.42s kick *** over the 2.73s.
bsa
"If they do not run, Then they will die." - Stonewall Jackson
'87 IROC, 355 TPI,700R4, Trick Flow Heads, Comp Cam, Comp 1.6 Rockers, Lucas 23# injectors, Edelbrock headers, Flowmaster 3'' exhaust, gutted cat,
Mallory coil, Mallory HyFire IV ignition box, Mallory Sidewinder 8mm wires, Autolite platinum plugs, K&N filters, Transgo Performance Shift Kit, Corvette Servo, 2,000 Torque Converter
Old Dec 20, 2000 | 08:58 AM
TomP's Avatar
Car: 1986 Firebird
Engine: 2.8 V6
Cool, congrats on the swap! Not sure about the noise, though.. could the driveshaft be scraping something under there? I had a panhard rod bolt come out after my swap (I forgot to re-check torque of all those bolts after a day or two!), and my driveshaft started smacking my exhaust pipe. Man I'm glad it didn't bust a hole through it!
-Tom P (Hot rodded 1986 Firebird 2.8l) from http://www.f-body.net/mailbag/3rd/3rd_mailbag.html message boards
---Think your car could be pic of the week? Visit http://www.f-body.net for details!
Old Dec 20, 2000 | 06:46 PM
irocbsa's Avatar
Man I bet it was scary to see that. Did you see my other post requesting your attention? If not, just for future reference, what did you use to plug the brake line junction block? I tried everything and nothing seemed to work. Thanks.
bsa
hectre13
Dec 11, 2023 08:14 AM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
sailtexas186548
Jan 19, 2016 12:21 PM
hectre13
Aug 26, 2015 08:17 AM
Leggman1
Brakes
Aug 12, 2015 08:39 PM
